Question about Dyson AM04 Hot Cool Heater/Table Fan - Silver
Dyson AM04 error code E4 any suggestions - Dyson AM04 Hot Cool Heater/Table Fan - Silver
E4 and E5 codes explained finally! E4 means motor is not spinning right, or reaching correct RPMs. E5 means heater in not working right. I will provide more detains next.
I had an AM05 which stopped working and it was showing E4 fault code and power light was blinking red. Occasionally as I turned it on motor would spin up for a second and then stop and fault code would display. Most of the time motor did not move. WARNING! I am an electrical engineer and have fixed countless things in my life, and I can say, taking this unit apart and putting it back together was very difficult. Do it at your own risk and of course, MAKE SURE POWER IS REMOVED WHEN WORKING ON IT.
First, remove the base ring and remove big screw in the middle. Next, disconnect the plastic white ring connected to the oscillating motor drive shaft. This requires removal of a C-Clip. (don't lose it, as it's likely to fly when being removed). Now pry apart the bottom section from the rest. Be careful as there are connecting wires all still there. Next, tilt the fan forward all the way and that will expose 4 screws in the rear, and when tilted the other was, two screws in the front. Remove them all. Now, disconnect connectors and start separating parts. Here are a couple of pictures I had taken.Dyson AM04 error code E4 any suggestions - 6da61f48-67d1-449b-a6d2-72e4af5aae9c.jpg
Of the two identical 6 or 7 pin connectors one has all red wires and the other is multicolor. When I disconnected the red one, the fault code went to E5. The red one goes to another board that has the heater circuit, so I deducted that E5 means either connections to the heater are bad, or heater is bad. I reconnected the red one and E4 came back. I disconnected the multicolor one and nothing happened, which told me the problem is there. I traced the wires and they were all going to the motor, which is further up the assembly. Getting to it was a real pain. To free the multicolor cable, you have to separate two rubber seals that allow the wires to move through an opening. If you can manage this, you can slowly get to the motor. When I turned the impeller I noticed that it was dragging, which explained the E4 code. When I turned it upside down motor spun freely and the fault code went away. So, I knew I had to fix the dragging problem, which was easy. Then putting it back together was a real pain. I recommend taking lots of pictures to remember what came from where. NOTE: There is thermal grease inter a metal heat sink. Make sure you don't wipe it off. It's essential, or heater semiconductors will overheat and fail. Also, MAKE SURE WIRES AT THE BOTTOM SECTION NEAR THE SWIVEL MECHANISM ARE DRESSED AS THEY WORE ORIGINALLY! Otherwise, they will rub and cam cause a fire. As you probably already know, there was a recall on these.
Anyway, hope this helps people. I have gotten so many great tips off the internet, I figured I had to contribute some as well.
God Bless.
Posted on Dec 31, 2015
  • Official Brand Answer
  • 2,572 Answers
Hi Stephen, it's Jack at Dyson.
If your AM04 is displaying an error code 4, you should be able to resolve this by turning off the machine and unplugging it from the power supply for 30 seconds.
You should then find that the issue is resolved when you test the machine. If you're still having difficulties after trying this, please get in touch with us directly for some further assistance. If a repair or replacement is needed, we can confirm if this is covered under your machine's 2-year warranty.
You can reach our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Mar 11, 2014
What does e8 mean on the display?
http://www.dyson.co.uk/support/am04/am04-irsbl/my-machine-is-not-working/e1-e5-e6-am04
Jun 03, 2015 | Dyson AM04 Hot Cool Heater/Table Fan -...
I am getting an E7 error code on two new AM 04 heater fans what does it mean
E7 error was an engineering code from an old batch of fans and that they had since fixed the problem.sell the old batch
Nov 09, 2014 | Dyson Hot Heater Fan AM04 - Blue
Dyson fan e3 error
Hi there, it's Jack at Dyson.
If your AM04 is displaying the F3 error code, I would encourage you to contact us directly so we can take some further details. When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We can take you through some simple troubleshooting checks, and if a repair or replacement is needed, we can confirm if this is covered under our 2-year warranty.
We'll look forward to speaking with you.
Mar 03, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
After a few minutes of heating, the machine shuts off and you see E7
If your AM04 displays an E7 error code after shutting off unexpectedly, we'd need you to contact our experts directly so we can take some additional details about the issue.
If you can contact us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU), we'd be happy to provide further assistance.
Feb 01, 2014 | Dyson AM04 Hot Cool Fan Heater White
Erroe message e8 showimng
I'm sorry to hear your AM04 is displaying an error code. When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 28, 2013 | Dyson AM04 Hot Cool Fan Heater White
Dyson AM04 e3 error message
I'm sorry to hear your AM04 is displaying an error code, but we're keen to help you check your machine is working as well as it should be.
When you have your AM04 to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 20, 2013 | Dyson AM04 Hot Cool Fan Heater White
Cool function stopped after 3 rd time use. error 4 displayed
Jul 31, 2013 | Dyson AM04 Hot Cool Fan Heater White
Dyson AM04 Hot Cool Heater/Table Fan - Silver Logo
2,105 people viewed this question
Top Dyson Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Dyson Heating and Cooling Expert? Answer questions, earn points and help others
