Mercury pig41z power supply problem in board smps is working but system is not switch on
  • 7,627 Answers
What is the motherboard in? Your computer specs/options will dictate what PSU to buy? Micro-ATX, what watts? Have you upgraded on the PC, anything?
Posted on May 02, 2013
Power supply
Any 450 Watt SMPS power supply is ok. Zebronic or Mercury retails around Rs.450 to 500. No need of costlier power supply like Corsair etc.
May 05, 2013 | MSI Custom 845 Ultra-c Ver:1 Motherboard...
I want to merury pig41z audio dirves window7
You can download the device drivers from Mercury WEB supportsite, select your model motherboard to download :-http://www.mercury-pc.com/downloads.php
Jul 23, 2012 | Computers & Internet
Ive had this bluray player for 2 years and it was working fine, then one day i tried to turn it on and nothing happened. i checked if the fuse was blown but i appears to be fine. so there is no power...
hi,
there is possibility of two complaints.
1, The SMPS power supply fault
2. the mother board fault.
if the SMPS is faulty the you can rectify the problem. If it is with the mother board the you have to contact the manufacturer .
First of all you have to check the SMPS ( switch mode power supply). you have to check the voltages at it secondary stage. 5v, 12v, etc
switched-mode power supply (switching-mode power supply, SMPS, or simply switcher) is an electronic power supply that incorporates a switching regulator in order to be highly efficient in the conversion of electrical power. Like other types of power supplies, an SMPS transfers power from a source like the electrical power grid to a load (e.g., a personal computer) while converting voltage and current characteristics. An SMPS is usually employed to efficiently provide a regulated output voltage, typically at a level different from the input voltage
for checkin the SMPS voltaes you need a multimeter. And check the voltages at it secondary stage
Added the inside view of BD 1600
if there is no outputs from the smps then you have to replace the SMPS drive STR ic near the big capacitor. Also ty to replace the OPTO coupler ic. y have to check the all resistors near the ic.
Remember one important thing that the capacitor can hold charge for some time even if you disconnect the power. so after removing the power. remove the SMPS very carefully. discharged the capacitor using a bulb.
i have also added a video for SMPS working for you reference will hep you for repairing your one
ok
Apr 07, 2011 | Samsung BD-P1600 Blu-ray Disc Player
Pc not switching on even after changing smps. even fan not switching on in smps
Dear,
You can test you smps simply by shorting any of the back wire and green wire. this will switch on your smps withour connecting with mother board. IF it the fan rotate, SMPS is ok.
If you need more trouble shooting on SMPS you have to measure the volate on each wire after powering on.
More info http://www.smpspowersupply.com/connectors-pinouts.html
Oct 13, 2009 | E-Machines 230W Micro ATX Power Supply,...
Smps transistors failed
It is difficult (or impossible) to tell exactly what caused the transistors to go bad. Sometimes they just fail because they were a little weak, or other parts went bad first and caused the transistors to be damaged. Parts get weaker and values change over time and with use, and failures can happen. The UPS can't stop damage to the power supply if some part inside the supply goes bad, but it is still good to have one. New 450 to 500 watt power supplies can be purchased for $30 to $50 (or more).
Nov 22, 2008 | ASUS K8V-MX Motherboard
Pc will not power up
Swimmie
to chack ur power supply open all connector from system board and drive. then conect power cable with powr supply and powr on ur wall outlet switch. than take mother board connector find green color wire and take a small pice of coper wire and connect it with this green wire and a black wire. then chack smps fan is moveing or not if it's moveing then ur smps OK.
Jun 27, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
CPU is not getting started
In SMPS 20 pin Connector please short the green and black wire with a twisterand on the smps. if the fan is rotating then the smps is ok
Jun 19, 2008 | Intel D845GVSR Motherboard
No booting is possible
check the connections between your mother board and power supply. if it is in tack and still wont work replace your power supply.
Jan 21, 2008 | ASUS P5RD1-VM Motherboard
Open Questions:
Save Your Important Data Getting Lost With Cloud Backup Solution of Dataalign These days, not only businesses but individuals increasingly need access to their data on the go without thinking about storage and hardware maintenance costs. Online Cloud backup provides an efficient solution and is swiftly attaining popularity. Before cloud-computing, end users stored their personal data on computer's hard drives and memory cards. Unfortunately, computers and mobile phones require physical proximity to the device to allow access to the stored data and are far more vulnerable to damage and accidental deletion. Individual devices need diligent support and maintenance, and ensuring the security of the data remains a challenge. With, Server Cloud Backup Solution end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software Cloud Backup publishing companies choose to offer Cloud Backup For Small Business web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. An online backup service isn't much capable if the process of restoring your data and getting back to being productive is not simple and quick. DataAlign offers a search tool to find a backed-up file. Also, the ability to replicate an entire folder-tree structure, helps with preventing bigger data losses. Versioning is another capability offered by DataAlign. This allows you to see earlier versions of a file in case you made Online Backup Pricing some undesired edits. This can also be termed as archiving function. You can set the number of versions and days you wish to keep any file and utilize the maximum available storage space. Using the version history, you can view the history of each file stored and undo mistakes, if required. Any accidental deletion of file from the computer and can be restored instantly as deleted files are backed up on the cloud. The moment the data is no longer required, you can setup a data destruction policy.
May 26, 2018 | Individual Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
