Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
BY PASS SAFTY SWITCHES
HOW DO YOU BY PASS THE SAFTY SWITCHES TO TEST THEM
  • Toro Master
  • 7,482 Answers
Hi twooofeather
You will remove the wires from the switch and tape them together.
You can then test your switch, and also see if it will crank up with the switch bypassed
Bud
Posted on May 01, 2013
Why can't I get cold a/c
did you evacuate and are the safty switches ok does it kick in the compressor
Sep 12, 2014 | Heating & Cooling
My check engine light is on,I could not pass my smog test,I was told it could be the cat & fuel injector module board?
1990 models is safty only here in nc, so it should pass. FIM is not likely..Cats and O2 senors very likely. Your solution can sometimes in few cases help
Dec 12, 2013 | 1990 Chevrolet Suburban
2000 series 2166 has volts will not turn over or try to start
check battery dead if not by pass the brake lever safty switch should start when by pass safty swich bad if not go to starter relay see if it is cliking if not bad if is look for fuse next to lower motor for starter see if blown has to be one of theses
Jul 19, 2013 | Garden
Triggers safety switch & keeps turning off
your safty switch shuts off your a/c replace your safty switch or by pass it
Jan 04, 2013 | Heating & Cooling
I have installed the Pass and Seymour combination GFCI and the test button disconnects the recepticles and the light remains on.
I believe the GFCI is only meant to protect the receptacle. Plig something into it and try the test button and it should work as expected.
Jul 07, 2011 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
How do you by-pass the safty switch to test it mine keeps triping after about 20 seconds of running?
Safety Switches should never be bypassed. If it is a safety switch you are experiencing problems with, a professional to be called in to determine and correct the cause of the problem.
Feb 14, 2010 | Heating & Cooling
I have no spark on a ducar 110cc quad
test all connections,for strength by bending them
Sep 22, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
Turn key to run and nothing happens pops fuse
Those safety switches you mention above is a good first place to look. Possibly the magnetic switch that makes connection with the battery and the starter needs replaced. When you jumped the starter to turn the motor over did you have the key turned to ignition? No spark can come from a low oil shutdown switch located somewhere on the lower part of the engine (either low oil or bad switch), if the key was on. The switch can be bypassed to test its condition. Keep us posted.
Jul 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
132 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
