Question about Philips Magnavox 20MS233S 20" TV
110v it is 110 v i plug it to 220v fuse not blown, where can i find schematic diagram
  • Philips Master
  • 12,061 Answers
Usually it "Blows" the primary winding of the step down transformer and often does nothing else, if ya lucky, so try replacing the transformer, sometimes it can also, as well blow the Bridge Rectifier OR rectifier Diodes, on the secondry side. I havent seen schematics have you Goggled for them?
Posted on Aug 08, 2007
SOURCE:
How to fix after putting in 220v to110v
not sure what problem is ,driers even in US are 220 not 110
Jul 09, 2015 | Dryers
Is it good for 220 v electricity, or only to 110 v ?
hi
does it allow you to switch from 110v to 220v ? if it does then you got to switch it according to the power supply from the plug point that you are going to plug it into. Do NOT switch it to 110v and plug it into a 220v plug point .
if it is only 110v and not switchable then you got to use the only 110v
Dec 01, 2014 | Dryers
How to wire it from 110v to 220v...
Most pumps have the eiting diagam on the outer motor housing. What brand is the pump? Some motors have a jumper that is moved over to 220v or 110v post and the red/black(220) or white/black(110) stay on the regular screw terminals. Ground stays on the same terminal usually a green screw
Jul 21, 2013 | Utilitech 1-HP Lawn Pump UTP10P1
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | GE Dryers
I accidentally plugged in epson nx110 to 110v when i shoudl have plugged it in 220v , burnt smell and no power at all
Not sure why it burnt going from 240 down to 110volts. The unit should not have worked. However, if it is a 110 volt machine and you plugged it into 240 volts... different story... At best you have blown the power supply board or board fuse.. At worst, the machine will be fried inside.
Aug 09, 2011 | Epson Perfection V500 Flatbed Scanner
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
Is kenmore 98702 220?? or 110???
if it has a small 3 prong plug then it's 110v for the washer but the dryer should be factory 220 volt however many were sold wired too! 110 volt! just look at the plug small plug 110v large 3 prong! 220v
Jan 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Dec 03, 2009 | Craftsman Saws
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Accidentally plugged the 110V to a 220V
you,ll have blown the PSU.
there maybe an internal fuse, located in the PSU. but if smoke was bellowing out, i,d say it went straight past the fuse.
New PSUs the best bet.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Philips Magnavox 20MS233S 20" TV Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
