Question about Generic Mobile Garden Hose Reel Cart Up To 225 X 5/8
Swivel type connector
I need a swivel type connector to join the external hose to the hose which is connected inside the reel. Can you advise please ?
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Aug 08, 2016 | Riccar Vacuums
HOw do I replace the riccar 8850 hose?
Inside the bad compartment you can see the swivel portion sticking through. You will need to take a screwdriver and push in on the tabs on the swivel to release it so it can be removed from the body of the vacuum. The new hose ans swivel will just push into the hole and the tabs will hold it in.
May 04, 2014 | Riccar 8850 Vacuum
Hoses are getting all twisted up. there is no clog and the hoses are stored in a straight line. Is the neck at the top of the vacuum not turning? if so, what causes this?
look on line for a pool hose swivel. your hose should be 1 1/2 as a norm . they don't know what a swivel is at all the pool stores I stopped at. should be able to improvise I stretched my hose out on the bricks for 2 days in the florida heat. it seems to have helped. but still look for the swivel connector,cut into hose about 3 ft. at either end you chose to mount the swivel. good luck. amf
Jul 31, 2013 | Hayward Navigator Pool Cleaner
Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Mar 16, 2010 | Hozelock Garden
How can i put on the snap ring on an eloctolux vacuum hose on the end piece of the hose; it is a swivel end and an older vacuum cleaner plastic canister type
The snap ring is generally found on a Canadian made LUX AP series prior to 1982 and it is in fact a coil spring you must leave the wiring off the handle. Be sure the steel cap and rubber o ring are on the tip of the hose. Slide the handle onto the hose with the hose tip facing upright. then with a small flat screwdriver separate the hooked tip of the spring from its body and run your screwdriver around the spring,feeding it into the groove inside the hose handle, spiraling as you go. similar to how you would feed a key onto a key ring. Before inserting the wire cover try to swivel thew handle it should rotate smoothly. Be very gentle inserting the wire cover pin as it will crack the handle. Use gentle pressure with pliers to start it , then squeeze it into place with your plier jaws fully open.
Post back to advise how you have made out
Nov 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Change Batteries in Pronto M91 with swivel seat.
Turned out to be a "doh!" moment. Use the lever on the side of the seat to permit swivel. Unplug Controls connector. Lift seat off unit. Remove battery compartment cover by loosening 2 Philips-head screws on the Charger cover at the rear. Disconnect cable to Electronic Controller at front of front battery. Disconnect the Red and Black battery connectors, the ones that join the 2 batteries. Lift out batteries. Transfer battery connections to new batteries. Reverse the above process to reassemble.
Solved this without any help from outsiders, including FixYa, who wanted to charge me for the solution.
Jun 12, 2009 | Invacare Supply Group Invacare Pronto M91...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing.  Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees.  Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do...  If it does help, please rate me!
Nov 27, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Won't power on.
It maybe cheaper by going to somewhere like the Radio Shack to get a fuse. Take the bad fuse with you and they should be able to fix you up with one.
Jan 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Generic Mobile Garden Hose Reel Cart Up To 225 X 5/8 Logo
69 people viewed this question
Top Generic Garden Experts
Dennis Key
Dennis Key
john h
Are you a Generic Garden Expert? Answer questions, earn points and help others
