Question about Soleus 12,000 BTU Mini Split A/C Heat Pump Inverter Technology
E6 error codes appears on my led windows what should the possible cause?
Error code 31 CD ROM driver not available how to install this driver
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Applies To
The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, and more.
Aug 16, 2016 | Computers & Internet
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
Dec 18, 2014 | Jilong Inflatable Hot Tubs: Prompt Set...
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
Mijn printer canon mp260 geeft error E6 wat betekend
To Fix this Error Code E6 on Printer Canon MP198, You only need Press Color Copy Button about 1 minute until the display in Progress.
It happened If you have CIS, the cartridge chip only known original ink from the manufactured. After original ink run out the E6 Error message will appear.
hope this helps
May 18, 2011 | Computers & Internet
F 22 just appeared on my washer. I tried restarting it and it made a clunking noise every 5 seconds and then f 22 appeared again. What does f 22 code for? Thanks,
F-22 is: CCU /touchpad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Your model's tech sheet gives error codes and remedys.
Duet HE manual and more HERE
Jan 22, 2011 | Kenmore Elite HE5t Washer
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
Soleus 12,000 BTU Mini Split A/C Heat Pump Inverter Technology Logo
153 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
