Question about Cellet Blackberry T-mobile Curve 9360 Sport Bluetooth Stereo Headset
Insert sim how to fix blackberry 9360 insert sim. where is the insert sim card ic?
    Master:
  • 826 Answers
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
Posted on Jun 29, 2013
Pse help need assistance wth change ob bis password im am active at moment by I changed sim card with son and it has upset my setting need to reset password I have doesn't want to work have cn
Just ask your son for the password. You cannot just swap out the sym cards between you and expect it to work. You should have gotten a NEW symcard for each and then set them up new.
Dec 01, 2014 | Cellet Blackberry T-mobile Curve 9360...
I'm using a blackberr 9360 and can't make calls out because of the error congestion
Try turning your Blackberry completely off and then back on so the SIM card can update the towers on power up. If this doesn't fix the problem, back up your data and settings and completely factory reset the phone. If that fails, you may need to call your Wireless provider to try to acquire a replacement SIM or replacement phone if your unit is defective.
Jun 30, 2014 | Cell Phones
How to remove the sim card from the blackberry 9360
You just pull of the back cover, remove your battery, and slide out the SIM card. :)
Oct 11, 2013 | Cell Phones
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
My blackberry says no signal
Remove your device battery, insert the appropriate SIM card and then restart your handheld. Next, open up your Manage Connections options again. Select Mobile Network Options and then change the Network Technology from 1XEV to GSM/UMTS. (Remember, if you want to go back to CDMA, you need to switch back the network technology option.)
Apr 12, 2013 | Computers & Internet
My phone is showing insert sim card
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Sep 29, 2012 | RIM BLACKBERRY TORCH 9800 TOUCH SCREEN...
How to open blackberry curve country lock
You have to Unlock Mobile Phone from network lock to use with other GSM Network Sim card....Get the Unlock code from the site Theunlockarena.com/blackberry/rs13wp8/ and Unlock it easily.
Jun 10, 2012 | Research In Motion Blackberry Curve 9360...
My blackberry keeps rejecting my sim card :'(
I have the same problem with my curve 9360. It reject the sim card, but it was wordkinh all right:
Dec 13, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
My blackberry bold says insert sim card
first is try to check the sim card cover, then the sim card conector, "the 6 pins",, if it will not work go to the hardware check the sim card transistor , if it will not work go to the POWER IC, then it maybe the possibility ,, try it
Apr 05, 2009 | RIM BlackBerry Bold 9000 Smartphone
Cellet Blackberry T-mobile Curve 9360 Sport Bluetooth Stereo Headset Logo
104 people viewed this question
Top Cellet Radio Communications Experts
Rigger
sandrasteven
Are you a Cellet Radio Communication Expert? Answer questions, earn points and help others
