Question about Kenneth Cole Mens Gunmetal-Tone Watch Transparent Dial KC1777
Large clock and second not working
This watch has three clocks. The smaller clock is working fine. but the larger clock and second had is not working. any suggestions?
  • Kenneth Cole Master
  • 18,394 Answers
Probably needs a new battery these watches have two batteries
Posted on May 01, 2013
Testimonial: "Thank you. I assumed there was only one battery for all the clocks. "
Kim Rogers Accutime Watch BK7R21
Send the watch back to Belk as it may have more problems than just a battery.
Jan 07, 2014 | Watches
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
I HAVE A CLOCK MOVEMENT KIT 1/4 INCH . THERE ARE 4 PIECES AND NO INSTRUCTION ON WHAT ORDER THE HANDS ARE PLACED ONTO THE MOVEMENT MECHANISM
mcdevito75 here, I do some work on watches and clock movements are similar. Generally the face/dial; of the clock will go onto the movement and is secured onto the movement, then the smaller hand is pressed onto the shaft in the center of the face/dial Gently place the small hand onto the shaft, NOW with twezzers apply gentle but even pressure onto the small hand just where the small hand goes onto the shaft, NOW, Make sure the small hand is pointing exactly to any of the hour numbers, place the larger hand gently onto the shaft, make sure the larger hand is pointing to the 12 O"clock useing the twezzers again press the larger hand onto the shaft, gentle even pressure on the hand just where it goes onto the shaft, both hands should now be pointing to the exact hour you lined up . Turn the hands too make sure they line up exactly at different hours. 3 O'clock, 6 O'clock etc. --------- NOW the bad news, if you need to remove the hands for any reason, even pressure must be applied to keep from distorting the hands while removeing them and for this you"ll need a Hand remover tool available on ebay This hand remover tool slips just under the hand right where it attaches to the shaft, you could use anything to do this such as 2 needles, but evn pressure must be ued to pry up and remove the hands other wise the hole in the hand will be dis-torted. Good Luck.
Feb 11, 2011 | Watches
Invicta 6280 , how to set time and does the large second hand move ?
Pull crown to position 1 and change date to yesterdays date , then pull crown to position 2, wind clock untill correct time appears (observe when date switches to observe the clocks am/pm cycle, this is useful to ensure the alarm goes off at the right time of day when set)
Dec 02, 2010 | Invicta Watches
Can I reset the second hand and the lower dial on the watch?
long answer with info given, but this is what will explain it all that small subdial at the 6 area is the second hand that runs at all times, large red hand is stop watch seconds,allso on the center pin is the minute hand for stopwatch 2 o,clock subdial is tenths of a second, for stop watch 10 o,clock subdial is hours for stop watch
Jul 09, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Analog second hand freezes periodicaly, digital clock works fine
mcdevito75 here, Sounds like the seconds hand is bent and hanging up on the face. See the repair service directory her at fix ya, bottom of the page click on repair service directory the watches.
Jun 24, 2010 | Timex Expedition 84601 Wristwatch
I have a cuckoo clock bought a rew years ago in Blackforest Germany when i visited the place. One of the chains has slipped off the wheel and so I am not able to pull it for winding. The chain is simply...
Do it yourself. There is no need for any repairs - you just have to put the chain back on wheel. Take a look on another chain in the clock and put the slipped chain back on wheel exactly in the same way as another chain. Use tweezers to reach the chain.
Rate me, please.
Mar 27, 2009 | Watches
Second Hand
smash it with a hammer
Feb 10, 2008 | Fossil CH2332 Wrist Watch
Problem with the large chrono indicator
Pull out the crown to the #2 position then push the start /stop button to move the second hand up to zero
Dec 09, 2006 | Skagen Men's - PERFORMANCE TITANIUM CHRONO...
Kenneth Cole Mens Gunmetal-Tone Watch Transparent Dial KC1777 Logo
187 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
