Question about Whirlpool Washing Machines
Whirlpool awm 1011
FA fault
5 Suggested Answers
XboxModifier
  • 123 Answers
SOURCE: Whirlpool AWM 8143
Hi
Is definatly FA?
Posted on Mar 07, 2008
  • 105 Answers
SOURCE: Fault F7 on whirlpool front loader
check drain pump for blockage
Posted on Mar 15, 2008
SOURCE: Hi. I have a Whirlpool 6th sense front loader 11kg washing machine (AWM 1008). After some very cold weather I now have an error code of FA. Do you know what this means and what I need to do? Thanks
Solution from a previous post i found for you.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Most of the solutions i found for this same error were very similar. If all else fails read the manual or get a new washer when possible.
Posted on Feb 17, 2012
  • 21 Answers
SOURCE: Hi my machine has come
Circuit Board Medics can rebuild the CCU with upgraded parts to eliminate the F11 and F14 error codes. Find more details and contact information at www.CircuitBoardMedics.com.
This video shows how to remove the CCU from the machine:
Posted on Sep 14, 2012
Whirlpool AAA Class Dishwasher
FA - Aquastop error
Check water supply. Low water pressure? Does the machine fill up with water in under 1 min? If not, thats your problem. If this happens during wash cycle, it could be the intake valve for the rinse cycle that is your problem, if you hava doubble/tripple intake valve that is.
Feb 17, 2016 | Washing Machines
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
  • Check the MCU
Feb 17, 2012 | Whirlpool Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
