Question about Vacuums
Wertheim 5030: need help with assembly - service manual or diagram would be great.?
Have been given a Wertheim 5030 vac to fix for a friend which is currently in pieces. I have worked out how most of it goes back together but am stuck regarding how the small tubes which detect any overheating connect into the senors on top of the control board. Was hoping maybe someone has a service manual with a diagram showing how the vacuum cleaner fits together? Also, there are two pieces of foam material, one which appears to wrap around the metal motor body, but the other larger piece I can only assume goes around the outside of the plastic motor housing -- is this correct? Thanks in advance to anyone who replies.
2 Suggested Answers
  • 146 Answers
SOURCE: Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Posted on Nov 09, 2007
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at:
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
Repair wertheim 3180
The hose probably is old enough that it will split repeatedly until you give up and replace it.
Jan 10, 2018 | Vacuums
VACUUM - 1. How to open up a Wertheim 5030 to get to the cord retractor 2. How to fix the retractor so that it retracts the cord.
Hi to do this you will have to somehow find a service manual, this will give detailed instructions on why and how. I have searched for one however i was unable to find any. Perhaps a direct plea to the manufacturer may help?
In any event, usually the is NO "Fixing" of the retractor, most often, the mount at the rear attachment of the coiled spring, brakes and this stops it retracting.
The fix is to replace the entire recoiler assembly. This is pretty simple job, if one can obtain the parts.
However my professional advise is to take it to a vacuum repair shop, (NB: Only take it to a repair shop that deals in YOUR brand) and ask for a "Quote" for the repair, I am sure it will be modest indeed. You see this is just such a common thing that they fix all the time.
Mar 26, 2011 | Vacuums
My wertheim 6030 is overheating I have changed the bag and filter even though there was no indication this was needed now it wont turn back on
Have you removed the bottom of the vac to be sure there is no obstructions? Check the intake area for an obstruction. Also look around the motor for vents. Are they clear? Most new vacs have a reset button. This will typically reset the motor. If none of this helps try reinstalling the filter and bag. I am not familiar with this model but most of this should apply.
Dec 03, 2009 | Vacuums
Vacuum won't switch on;got it apart;cord ok;need wiring diagram
Its a great idea to write on paper how its connected . So it helps with dis assembly & reassembly . I tried a Internet search . Looks like it'd cost money for a service manual. Though. I found a Kirby Spares Website that could help. Although it doesnt have Document downloads with repair help. There are spares & there is a telephone number for an engineer available during office hours. That you could ask for repair help. With wiring connections for your Kirby G3.
The Engineers Telephone Number is 0845 388 9301
I repaired my Parents Kirby Heritage some while ago. With a new set of Brushes. Bulb Repair.
They are a Great Machine. Bit Expensive. Though Tough & Well Made !
May 24, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Old red and black Genie Shop Vac
Posted by girl power on Jun 10, 2008
A Wheel or disk has come off of the motor. I would like to get a copy of the user manual to see if I can determine where it came off of. This Genie Shop Vac was given to us from my father-in-law.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check with the manufacturer Shop Vac to get an owner’s manual for the older Genie Shop Vac would be @ the Shop Vac Website and or Customer Service of which I will give you @ the bottom of the response. Other wise check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Aqua vac vacuum cleaner
yes you do need water... but water vacs dont clean as well as a good old suction driven machine.... aerus has several great models available
Feb 05, 2008 | Vacuums
Vacuums Logo
107 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
