Question about Compaq Presario M2000 Notebook
Pc card eject button popped out and won't go back in
    Master:
  • 435 Answers
I've had that happen before. I just started using the tip of a ballpoint pen to eject the card. Believe me, if it doesn't just slide back on, you might have to disassemble the laptop casing to put it back on...big hassle. I suggest you just use a pen, pencil or something similar to pop out the card.
Posted on Mar 29, 2014
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
My Samsung Galaxy Tablet won't turn on
Hold in the power button for 60 seconds and it should come back on.
Jul 18, 2012 | Samsung Galaxy Tab 2 7.0
HP Z1 WORKSTATION WON'T EJECT CD
Make sure the computer is turned on then Take a Paper Clip (Gem Clip) and straighten it out then kneel in front of the desktop facing the cd drawer. Look closely at the drawer and you will see tiny hole where you will insert the paper clip (Gem Clip) and at the same time Press the Button on the cd drawer while applying pressure by pushing the paper clip (Gem Clip). The drawer will pop open. Don't worry about breaking something, that's why that tiny hole is there.
Jun 02, 2012 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
I can't remove the old filter to replace it. You're supposed to push the button in and it would pop out, but it won't go in. 56166501 is model.
If its been some time since you last changed the filter then you may need to pull the filter holder while holding the eject button. Don't twist the cap on the holder, just pull.
If you can't get a grip on it and the eject button still doesn't work then remove the base grille by openeing both doors and pushing the top and pulling the bottom to give you better access to the eject button and filter holder.
Jun 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
I can't get the memory card to stay in the camera. The eject buttom pushes it out.
You haven't said which KM model you have. But on most of them one push on the eject button makes the eject button pop out in order to be ready to use on the second press which ejects the memory card. After pressing the button all the way in to eject the card, the button should latch back into the "parked" postion.
Before re-inserting the memory card make sure that the eject button is already in the parked position. If it isn't then you'll get the problem which you describe.
Oct 12, 2009 | Konica Minolta Cameras
The nexlink CL51 has a small button that you depress to eject a plastic card. How do you keep the button from sticking out?
After you eject the PCMCIA card you can push the button in until it clicks and stays in. Now you insert your PCMCIA card into the slot and if you want to eject the card you push the button and it will pop out then press the button to eject the card.
If this pressing the button in doesn't lock the button in place, then the spring catch on the button is broken.
Jul 08, 2009 | Computers & Internet
Card Eject Button Not Working
I hgave the came camera it does take two pushes to get it to lock down - just a quirk I guess
Jul 30, 2007 | Olympus EVOLT E-300 Digital Camera
Compaq Presario M2000 Notebook Logo
149 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
