Question about NetGear WGPS606 (WGPS606NAR) Print Server
Printer server, wireless, detached cable now won't print
I have a Netgear WGP5606 print server, I detached the cable to the Netgear router and now I can't print, Help doeas anyone know how to fix this problem?
  • Lizzydriptin Aug 08, 2007
    Thanks will give it a try, Thanks for your help!
    Lizzydriptin
  • 12,061 Answers
It is because the WiFI connection is more than likely on another IP address ie: Cable:192.168.0.1 type thing. WiFi:10.1.1.1 Type thing... so ya have to configure ya access and point ya printer in the right direction, so reinstall ya printer & driver and when it asks where the network printer is, point it to the correct address of the router's port..
Posted on Aug 08, 2007
SOURCE:
Can I connect non-wireless printer directly to netgear rangemax wpn824?
No you cannot.
To make your printer a network printer you need to connect your printer to a network print server and the connect the print server to the Netgear using a LAN cable.
Feb 14, 2013 | NetGear RangeMax WPN824 Router
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Motorola SBG900 and Netgear print server
Yes you can , just configure the wireless settings of you SBG900 to the print server and once its done you should be able to make everything working again....
Dec 18, 2009 | Arris SURFboard SBG900 Wireless Router...
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Need to bridge my netgear wgp5606 to my tv
Please let me know about the existing wireless network being used so as to configure the required settings on the print server.
Oct 21, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
I wanted to set up the printserver wirelessly but everytime my computer searches for the printer server, it only registers in the wizard if i connect the WPS54G to the router. If i do this, i am able to...
The printer and print server has to be connected to the wireless router by a network cable for you to print wirelessly from the laptop.
If possible connect a long network cable between the print server and the wireless router or move the router next to the print server and printer.
You maybe able to use a wireless repeater/extender but is it worth the added costs and complication. The extended range would invite hackers unless you secure your system.
Aug 01, 2009 | Linksys Wireless-G WPS54G Print Server
Can't connect WGPS606 wireless printer server to cable router
suggest plugging print server directly into p.c via blue ethernet cable during setup. Then run setup program and then pick an ip address that works with your router (in same network ip range of router) that does not clash . I would use print server as a switch if it is close to the router by ethernet cable between router and wireless print server. Then both should work
Wireless to server and other wired computers as well .
Feb 06, 2018 | NetGear WGPS606 (WGPS606NAR) Print Server
Netgear Wireless print server WGP5606
Hoopers statement is generally correct, but INCOMPLETE in this case. It cannot be used as a router, because this device has no input for the network connection from your cable modem or other broadband device. HOWEVER, this device is also a wireless bridge. That is, you can use it as a router to connect multiple computers in your SOHO network (but not to the broadband device) and you can use it to wirelessly route a remotely located computer or device, such as a PS3, a TIVO box, etc. that cannot be provided with a wireless network adaptor, to a wireless router that is connnected to your broadband device.
Jun 25, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Signifcant delay when printing
Your post does not mention all IP addresses in use, and which devices use wireless. That information would be helpful.
Is it possible that you are getting an IP address from a router for your internet access, then when you try to talk to your print server it may be trying to assign an ip address too.
(Sometimes a wired computer also has wireless enabled, which can cause an issue when one ip address has already been received on the wired connection and a wireless connection is also trying to connect.)
Mar 29, 2008 | NetGear PS121 Print Server
Open Questions:
NetGear WGPS606 (WGPS606NAR) Print Server Logo
390 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
