Question about Kodak I260 Captiva IA-Express Path-Through Scanner
Kodak i260 problem
A thin line appears periodically down the right hand side of my white documents. I have cleaned, etc. to no avail. How do I correct this problem? Is it a setting issue?
  • 1 more comment
  • GAPD May 20, 2008
    We have a i260 that inserts a stay line down the forms that are being scanned. There does not appear to be a pattern to the line, but it adds data to the froms that does not exist quite often. Does anyone know how the line gets inserted and how to get rid of it??
    Thanks,
  • dothawaii Nov 14, 2008
    We have the same problemw with the Kodak I260 scanner. 2 veritcal lines are formed on the back page only. Have cleaned the imaging guide & did not see any scratches on it. The lines don't appear to be lined up with a roller and they are symetrical.
    Some added information to get to the mirror for the back copy in the top section of the scanner. You will need to remove 4 screws. To get to all of the screws you will need to first open up the scanner to get to bottom of the top half of the scanner. One screw wll be under the top cover, at the very top, on the Right hand side of the scanner near the wire tape assembly. 2 of the screws will be at the bottom of the top section by the hairs at the interesection of the top and bottom of the scanner. To get to the last screw you will need to pul out the Separator Module in the center. The screw will be behind it. To put put back the Separator Module you just snap it back in. You may have problem with a large screwdriver, in that case use a small one blade screwdriver. Good Luck.
Is the image on the front or rear image?
anways-
remove the image guides and clean with soft lint free cloth in a longitudinal manner.
Recalibrate scanner using clean calibration sheet.
If line still persists remove back cover and slide out mirror/camera assembly. use canned compressed air to clean mirrors and finally the camera lens.
Posted on Oct 12, 2008
  • 490 Answers
A line appears if a dust particle on the scanner glass is scanned continuously. Clena the galss with Isopropyl alcohol, dont use any solvent. If the line persists even after this, there could be some sensor problem. If accidentally a paper with a staple pin is inserted, the pin can cause scratch and a line will appear.
S. Mohan
Posted on Jul 31, 2008
I have a thin white line down one side of the print. i have cleaned each rolling feeder and also the thermal head. but still the white line is there.
I have noticed this with many printers, and usually the problem is the Drum Unit. Once the drum has become worn out, you will start to see lines through your documents. However this generally dont happen to the drums unless the machine has had alot of use.
I hope this helps you,
Regards,
Nico
Jul 05, 2011 | Kodak Photo Printer 6850 Thermal
Black line down right hand side how do i get rid
Open the original feeder of the fax and look for dirt on the platen(thin glass ) glass usually white out or postit glue clean with damp rag or isopropyl alcohol
Good luck
Apr 19, 2010 | Office Equipment & Supplies
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
A red line appears down the right hand side of my
dear friend . .
the line appears due to some tecnical fault of your monitor
if u have still in warranty period then just change it soon
Oct 06, 2009 | SNK Cibox Inter@ctive C2201 22 inch LCD...
The scanner makes unwanted vertical lines down the document
Clean Optical path to camera lenses back and front, then Calibrate through the Kodak SVTool.
Oct 06, 2009 | Kodak i260 Duplex Color Scanner
Kodak I260 large black line.
It may be inside see this website for how to fix an Hp which is similar http://www.willshak.com/scanner/
Apr 20, 2009 | Kodak I260 Captiva IA-Express Path-Through...
I260 insufficient memory error
If you start scanning Documents over 17 inch, then its best to swap out the 64mbyte for a 256mbyte card on the mother board cpu 100/110.
You can tell wants loaded by looking at the Info tab in the Kodak Scan Validation Tool.
Nov 03, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak I260 paper tray not lowering after tray emptied
The Kodak i260 has a fixed Paper Tray and does not automatically move up and down?????
Oct 05, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak i260
Either the papers are sticky or there may be a stapler. Remove the stapler pins. This can happen if the papers were bound together, the small notches can imitate the stapler pin! Fan the documents and try again.
S. Mohan, Chennai, India
Sep 24, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak I260 Captiva IA-Express Path-Through Scanner Logo
555 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
