Bose Lifestyle 28 Series III DVD Home Entertainment System - White Logo
A
Anonymous Posted on May 01, 2013
Bose av48 media centre
Code to get region 1 on region4
How can IO down load a Manual for Bose AV48 Media Centre?
Do you mean the Bose Lifestyle AV48, the main unit in the Lifestyle 48 DVD home entertainment centre? If so, the Installation and Operating manuals are available on the product page: https://www.bose.com/en_us/support/products/5_speaker_home_theater_support/ls48_series1.html#v=ls48_series1_black . The direct link to the operating manual is currently https://assets.bose.com/content/dam/Bose_DAM/Web/consumer_electronics/global/products/speakers/ls38_series1/pdf/opg_en_ls48_series1_ls38_series1.pdf .
I hope this helps.
Can i use a non-bose amp to drive the speaker system from my Bose AV48 system. The original Bose amp and dvd player is too glitchy
Yes you would be able to use a non bose amp. All the speakers should have crossovers in them, If you do start at a low volume first, you can blow your speakers if your amp is too big and volume is too high.
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
6helpful
Unlock code bose 321 GS III series
1. Insert a DVD which does not work due to region code error, then
2,.- Press right arrow
3.- Press up arrow
4.- Press Shuffle Button
5.- Press Stop Button
6.- Press and HOLD Mute Button
The tray disc will open and the will close.
Thats all....the Bose DVD media will be Multiregion....
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
2answers
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
3helpful
2answers
Code to unlock to region 4, it's region 1
1.- Insert Region 2 disc (an error message will appears)
with the remote control...
3.- Press up arrow
Adding SA-3 amp
your media centre and sa-3 are from two different countries they work on radio wavs, if the amp and media centre are different they will never work sell the amp and buy one that is the same region code as your media centre
Frozen bose lifestyle 48 IV
turn off the accoustimas, unplug the power code from the accoustimas and the media center and leave it for 15 sec. Then, plug the power code onto the accoustimas and turn it on. then plug the power code of the media center on. Turn media center on.
hope this helps
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
