Question about Coffee Makers & Espresso Machines
Plus4you programming looking for use manual Astoria plus 4 you Model SAEP/2-4U
2 Suggested Answers
SOURCE: Astoria SAE 2 Programing
The key is that you have to HOLD the programming button in for about 5 seconds before the system will go into programming mode. All the lights will come on and you will know you are ready to program the various shot buttons.
Posted on Dec 23, 2008
What amperage does my astoria machine require?
2GR 19.6 amps- 3GR 24.9 amps - 4GR 31.6 amps -->> This INFO From the site .........
http://prima-coffee.com/sites/default/files/astoria/automatic/plus-4-you.pdf
Rapallo - 18.2 amps
Gloria AL2 ...21.7 or 17.8 amps FOR 120 or 230 volts
If that is not the answer go tot he PRIMA-COFFEE site and dig in!
Aug 24, 2014 | Astoria Coffee Makers & Espresso Machines
Hi I do have a problem with my Astoria SAE2 Coffee Machine. One side of the machine working perfectly. On the other one there are 4 buttons and those are flashing red. during this process we can not serve...
Sounds like the flowmeter which sits under the drain tray is not working properly for that side, or the programming is off, or the head is blocked. There is a manual switch for that head when you press it does water flow? If yes then problem is flowmeter.
Jan 24, 2011 | Astoria Coffee Makers & Espresso Machines
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
How do I program an astoria SAE-2 espresso machine?
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Sep 28, 2009 | Astoria Argenta SAE-2 Espresso Machine
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Directions on programing the Divina espresso machine
Depending on the model, if you remove the top cover you will find a small toggle switch on the right corner of the machine, just above the fitting for the steam valve, switch it on, then press prog/stop button all the lights will be on , press shot button when you get desired volume press shot button again or press stop button. When you are dont programming return switch to off position.
Mar 25, 2009 | Astoria Divina SAE-1 Espresso Machine
Nov 07, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria SAE-2
Contact Astoria and I'm sure they can provide one for you.
www.geec.com
Mar 14, 2008 | Astoria Argenta SAE-2 Espresso Machine
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
