Question about Home
I am looking or a stockpot that holds about 11 quarts and the handles are cool. my last one kept burning my hands when i lifted it!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 43 Answers
2010. How do I unlatch hood after a little bump up?
You have to reach your hand in under the center of the hood, then feel for a small handle and lift up on it. Then hold the handle up while lifting the hood at the same time.
Oct 18, 2015 | BMW 3 Series Cars & Trucks
Tip
HOW TO REMOVE REAR DOOR PANEL GRAB HANDLE INSERT
I FIGURED HOW TO REMOVE THE GRAB HANDLE INSERT MYSELF. YOU DONT HAVE TO REMOVE DOOR PANEL TO TAKE THEM OFF. UNDERNEATH THAT INSERT ON EACH END THERE IS A HALF A U ,THAT SLIDES IN EACH END AND HOLDS IT INTO PLACE ON THE GRAB HANDLE. THERE IS A LITTLE OPENING AND THE BOTTOM OFF THE GRAB HANDLE . JUST PUT A SMALL BLADED SCREW DRIVER IN THERE AND LIFT UP AND THEN GRAB WITH YOUR HANDS AND LIFT OFF. THERE ARE METAL CLIPS IN THERE HOLDING IT INTO PLACE
on Feb 29, 2012 | 2011 Buick Regal
Is it better to have a stockpot with a spigot for making consomme?
If your stockpot has a spigot then you wont need to lift a heavy, hot pot! Its great because you can drain out all the liquid without breaking the raft, so the liquid wont get clouded.
May 01, 2013 | Home
Where are the camera lens located on the lift gate?
check under the lift gate handle or in the handle, a quick trick would be to have some one inside truck put in reverse apply e brake and also hold the brake and wave your hand around the rear handle and let them tell you when you are in front of it.
Oct 30, 2012 | 2011 Dodge Durango Citadel
I have lost my operating manual for my pressure cooker
Hello do you happen to have a model number so I can provide an exact manual? For instance this is the manual for the wolf gang puck pressure cooker/ stockpot click this link http://www.wpcookware.com/instructions/BPCR0005.pdf please look at this link and compare if this is the cooker that you have or if it is not please message me back the model and or serial number so that I may provide the exact manual and not one that is generalized. Thank you again I await your reply
Rick
Oct 17, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
How do you replace door handle on maytag maf1375 washer
Hi
You have to replace the door lock assembly. For that open the door and remove the four screws that hold the front panel. There are two on the door hinges and two on the other side. Then remove front by rolling the edge out. Now you will need to get the top lifted up. Remove the four screws that hold the soap dish trim on the top. Then there is a bracket on the front corners that have to be removed. Now you can lift the top and see the door lock switches and wax motor. You can remove the three top screws near the timer and flip the top down so you can look at the control board on top the washer.
Check the R-11 resistor to see if it is burnt. This resistor burns out when the door lock wax motor fails.If the resistor is bad you should replace the control board and the door lock wax motor
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 05, 2011 | Washing Machines
Keeps burning out when i replace them-headlights.
I had the same problem with 2 different vehicles. Kept burning out the replacement bulbs, and they never lasted very long. I was told that I should never touch the bulbs with my bare hands/fingers because it transferred oil onto the bulb which would in turn create a hot spot on the bulb and cause it to burn out. I tried changing the bulb while wearing hospital type thin latex gloves. I also made sure not to touch the bulb to anything else while guiding it into its proper position. I know it sounds silly, and it may just be a coincidence, but I have not had the problem since I started installing bulbs this way.
Apr 25, 2010 | 2002 Nissan Xterra
R/H door swings open too easily and hits counter behind door.
Hi LC,
Your fresh food lower door hinge cam assembly has failed and needs to be replaced. Not a big deal to replace, really... but you have to remove the FF door to get to it. <---which is VERY simple to do. But first thing first, right? You'll obviously need the replacement part on hand prior to the repair, so the part number is WR02X10779. You can see what it looks like here (you could also order it here if you don't have a local appliance parts retailer).
OK, now that you have the cam assy., Empty out all the goodies that you have stored in the FF door shelves. Then using a sturdy step stool, remove the upper hinge cover. Below the cover, you'll find three more screws, remove them (just so you know ahead of time... after you remove the last of the 3 screws, the door is no longer "attached" to the frame, so hold on to the door while removing the last one, OK?). Now all ya have to do is lean the door forward (from the top) and lift it off of the lower hinge/cam assembly.
Now that the door is off, all that's left to do is remove the old cam assy., install the new one and rebuild everything! Easy Breezy! You'll be in and out of this job within 20-30 minutes.
Oh yeah... one other thing. When you replace the door and are putting the top hinge back on, put all 3 screws in but don't tighten them yet. You'll need to "level" the door and THEN tighten them. Just lift the fridge door handle 'til the top of the door is level with the Freezer door, tighten the screws while holding the door in this position, deal? Cool.
Hope this helps!
SG
May 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Home Logo
810 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
