Question about Science & Laboratory
What sizes of hot plates are there? - Science & Laboratory
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 91 Answers
I cant find a vin on my suzuki atv. Is there one on the motor i can use instead?
look for the serial number on the frame.. sometimes there is a plate with the info you need on the steering head, or on one of the frame rails... then get the serial number off the engine case... they might match..:)
..If the Suzuki model/year/serial number plate is missing completely.. you may have purchased a "hot" one.. you can find the engine size by looking at the bottom of the outside of the cylinder.. it usually has the "cc" size cast into it... ie.. a "246 cc" would be a 250..
good luck.. be careful..
please mark as helpful.. thanks!!
Jul 18, 2017 | ATVs
2 Hot plates have stopped working wont switch on
Age? 20 years? Double check plug, wiring at the plug. My Toaster just gave up at that wire plug junction. Same thing at connections to switches are possible. If at plug just install a new plug although a new cord with plug may solve the at switch connection in the future. Make sure the cord size is equal or better than original to prevent heating in the cord.
Mar 12, 2015 | Kitchen Ranges
Can a ring made of 18k gold over silver be re-sized?
In the past, rings that were plated silver or plated gold couldn't be resized. However, in 2010 JCPenney started resizing rings that are plated gold or plated silver. Since it's been four years that JCPenney started this service, I'm sure other stores and jewelers offer the service too. I do believe they can resize rings by two sizes.
Jan 29, 2014 | Icz Stonez 18k Gold over Sterling Silver...
Tungsten plate Manufacturing technique of
This "question" is an attempt at spam. It's not a very good one since it fails to provide any contact information so anyone who might be interested in their products wouldn't be able to get any.
Oct 21, 2013 | Motorcycles
What is a Laboratory Hot Plate?
Wikipedia says: A hot plate is a portable self-contained tabletop small appliance that features one, two or more gas burners or electric heating elements. A hot plate can be used as a stand alone appliance, but is often used as a substitute for one of the burners from an oven range or the cook top of a stove. Hot plates are often used for food preparation, generally in locations where a full kitchen stove would not be convenient or practical, as hot plates are easily moved from one location to another.
May 01, 2013 | Science & Laboratory
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
WHAT SIZE HOLE IN JET ON HOT WATER HEATER TO CHANGE FROM NATURAL GAS TO LP GAS
That doesnt work with these units they are manufactured gas specific. The manifold plate would need to be changed as well as notification to Noritz to have a new serial # issued. PC board reprogram required, etc. Buy a natural gas or LP model.
Apr 27, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
1996 Dodge Intrepid Wiring Schematics for the signal light - Signal lights and wipers do not work and I bought the part (switch) and it still does not work.
check for bad flasher, or lost ground. if not pull the entire light assembly off the vehicle and there is a clipped in plastic plate in the back of the rear assembly that houses the bulbs. this plate has metal bars that run thorough the inside of it to control the individual bulbs..IE some work, others dont. what happens is the plastic plate gets too hot and disloges the bars, or causes corrosion and bingo no lights. the plates are a common problem for the chrysler mid size cars, mostly the taillight assembly. hope I helped
Sep 11, 2009 | 1996 Dodge Intrepid
My license plate lights are out...what kind of bulbs do i need??
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
Trunk/Cargo Area Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
Sep 09, 2009 | 2002 Hyundai Accent
Plate getting too hot
I don;t think your plate is micorwave safe. Put the plate and a glass measuring cup with water in the microwave for 1 minute, if the plate is hot and the water is not the plate is not microwave safe. IF the water is hot and the plate is not. I don't know what the problem is
Sep 16, 2008 | Kenmore Microwave Ovens
Science & Laboratory Logo
433 people viewed this question
Top Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
