Where can I buy
I've got a faulty american Dynamics 17" monitor that appears to have a faulty power board, anyone know where I can purchase one from, the number on the board is 03A94V0 but a google search for this doesn't help me much and the only image I've found showing it looks nothing like what I've got.
techman
  • 3130 Answers
SOURCE: Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Posted on Jun 20, 2007
Benimur
  • 6966 Answers
SOURCE: Broken grill Panels
Pls try here and look for an authorized parts distributor near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 30, 2008
  • 4 Answers
SOURCE: blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Posted on Sep 12, 2008
  • 11 Answers
SOURCE: Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs
Tyris Model: F179
No Power
Purchased an AsIs non-Working Tyris F179 from Goodwill for $15. Opened the case, found no swollen capacitors. Tested the capacitors on the power board and found C203 680uf 16v and C202 680uf 16v only partly working. Could not find a pair of 680uf caps and since they were in paralell on the same traces I removed both of them and substituted with a single 1500uf 16v capacitor. Next, the video board does have a Novatek chip much like the Novatek chip in the Samsung 710n but look closely at the 5 and 6 legs, they are not being used in the Tyris design so the 5/6 50ohm resistor fix is not needed here. Did find C107 , C16, C50 weak, all 47uf 16v, so i replaced them. Reassembled and now have a great picture again.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
For Reference_Novatek Chip goto near bottom of page
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
Posted on Mar 09, 2009
  • 81 Answers
SOURCE: VIzio VU32L - Backlight but no image, no menu
check if the fuse is blow on the t-con board and there are 2 or 3 fuse on the main board 1 feeds the voltage to the t-con
Posted on Apr 22, 2010
Samsung LCD monitor Model 740N no display.
pls chek 1000/25cap ,and inverter fuse, and 5402 ics
Jan 11, 2013 | Samsung SyncMaster 740N 17" LCD Monitor
Compaq Presario CQ56-115DX shows a blank screen on boot, but runs perfect on external display
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 24, 2012 | Compaq Presario CQ56-115DX Laptop
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
Admca1lcd20w american dynamics monitor/camera unit will not power on after power failure in the building
hi please check your power cable and data cable.if he does not work check his cable jack.thanks
Mar 01, 2011 | American Dynamics ADMCA1LCD20W Monitor
Need to buy a power cord to replace the original. Do you know where one can be purchased?
Modern monitors and desktop computer use universal power cables, so you should be able to go to an office supply store like Staples or Office Depot or an electronics store like Best Buy and ask them for a monitor power cable. It will have a three-prong end to plug into the wall and a six-sided end with three recessed slots to plug into the monitor.
If you want to buy online, monoprice.com has grest prices on cables.
Good luck.
Jun 09, 2010 | AOC LM742 17" LCD Monitor
LG W2243S - Keeps going into Safe Mode
Check your power source, maybe it is not getting enough power or getting to much power. Its happened to my amps before.
May 25, 2010 | LG 22" FLATRON LCD Monitor
HCN5529W crt driver problem
You can go to any Samsung dealer and ask them for that.It is most probable that they may not give it to you so go to a local shop and buy a multimeter and satrt checking the parts of the driver board. Replace the part that's faulty with a new one of same rating.
Mar 16, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor will not turn on
Most monitors require an input signal before they will resume from a low power state. Other possibilities include a faulty back-light inverter, in which case you will be able to see objects that would normally appear on screen, but they will be extremely dark.
Jan 22, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Board FSP048-3PI01
I found an LCD inverter database list that has the board listed but I am not sure what to do after that. (https://www.combase-direct.com/html/csshop/images/data_sheet/gy15vtsn_edc_parts.pdf) The site also said:
"You can search for updated part codes through CMS web site.
URL : http://ecms. samsungelectronics. com/"
Jun 17, 2008 | Samsung 710N V2 17" LCD Monitor
Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
Mar 19, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
