Question about Science & Laboratory
I'm looking for a big blender, around 6 galons
    New Friend:
  • 23 Answers
Posted on May 01, 2013
My blender is model# KSB5 & it works fine; the problem is the 'jar' is stuck onto the unit. I cannot remove the canister no matter how hard I try. Help?
This is a most unusual case, under the circumstances I would contact KitchenAid for a solution, have you tried turning canister clockwise and anticlockwise, should unlock in "anticlockwise position" if no luck contact the manufacture.
Mar 31, 2012 | KitchenAid KSB5 Professional Stainless...
Rewire blender
Simple answer; no.I don't know where you are but step-down transformers are a pretty common item (some are even reversible) but make sure that the transformer's power rating is adequate for the blender; for example: if the blender is rated at 200 watts or 1.8 amps (roughly the same at 110V) use a transformer rated at least 50% higher to avoid having the output 'sag' under load.
Dec 29, 2011 | Blendtec Blenders
I need the plastic piece that goes on the back of the Margaritaville DM0500. I think it holds the run off from the front of the machine???? I don't really know it's purpose. It's shaped to...
The part you are looking for is called the Ice Melt Reservoir. It collects the water from the melting ice left in the Ice Reservoir.
The manufacturer has a Parts & Accessories page here:
http://www.margaritavillecargo.com/accessories.aspx?pid=1375
Parts & Accessories for your blender are also available here:
http://www.blenderexpert.com/margaritaville-blender-parts.html
Unfortunately the Ice Melt Reservoir does not look to be a stocked part. I would recommend you contact the manufacturer directly to inquire whether this part can be made available. See their webform here:
https://secure.margaritavillecargo.com/ContactUs.aspx
For future reference your Manual can be found here:
http://www.margaritavillecargo.com/manuals/MANUALS/DM0500-000-000_43_27862119.PDF
Jun 21, 2011 | Margaritaville DM0500 Blender
I have a FORD Econolinen 1993. When I drive he abuse 45 ltres of gaz on 100 miles . Is this normale ?
on normal that trk should be around 6-7 gallons used per one hundred miles drove. i based that at 15 mpg. now that is also based on a V8 engine. now 1 gallon of gas is 3.78541178 liters which totals 12 galons of gas to 45.42494136 liters. This would mean that it took 12 gallons of gas to travel 100 miles which totals 8.3333333333 mpg. not as good as i would have thought. 8 miles per gallon (mpg) hell that engine must be a big block 460. If it is that big cubic inch i could understand but any other motor should do better mpg than 8.3. so i agree that is not normal, tune up, or look for fuel leak in the fuel supply or( feed ) line. From the tank to the motor. This must be a canadian truck yes? well hope for the best or trade that guzzler in for a new breed. stay warm!
Jan 14, 2011 | 1993 Ford Econoline
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Salton Blender
Contact the manufacturer of your blender, if the manual is around look in the last pages.
Oct 23, 2008 | Salton FBL500SS 3-Speed Blender
Vitamx blender works at low speed, but blade stops moving at higher speeds.
Did you ever find a way to fix your blender? I have the same problem, I'm sure it's a loose wire but can't figure out how to get to the wires.
Aug 29, 2008 | Juicers
Science & Laboratory Logo
732 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
