Spit a/c inverter not running in the display panel indicates error
  • 3,799 Answers
Make, Model and please ask a question, Also ensure you are asking in the correct section. Thanks.
Posted on May 01, 2013
Testimonial: "sorry for my mistake..thanks "
Sony Bravia KDL-40EX500. Plugged in power and no backlight. No pic no sound. Could it be the power board or inverter board? How can I test these boards? Thanks.
SELF DIAGNOSIS FUNCTION
The units in this manual contain a self-diagnostic function. If an error occurs, the STANDBY LED will automatically begin to fl ash. The number
of times the LED fl ashes translates to a probable source of the problem. A defi nition of the STANDBY LED fl ash indicators is listed in the
instruction manual for the user's knowledge and reference. If an error symptom cannot be reproduced, the remote commander can be used to
review the failure occurrence data stored in memory to reveal past problems and how often these problems occur.
DIAGNOSTIC TEST INDICATORS
When an error occurs, the STANDBY LED will fl ash a set number of times to indicate the possible cause of the problem. If there is more than
one error, the LED will identify the fi rst of the problem areas.
Result for all of the following diagnostic items are displayed on screen.
If the screen displays a "0", no error has occurred .
Diagnostic Item
Description
Number of times Standby
LED blinks Possible Location
Main Power Error 2 G2HE/GD2 (Power) Board
Audio Error 3 A (Main) Board
Balancer 4
LCD Panel
Inverter Board (ETC-Inverter MT Board) for 32" & 40" Models
TCON Error
5
LCD Panel
TCON Control MT Board
HFR Error 5 LCD Panel
Backlight Error 6
LCD Panel
Temperature Error 7 A (Main) Board
This should help you narrow it down. I am also attaching the service manual for you. https://files.acrobat.com/a/preview/16a56e45-a439-48bc-8770-21638f2bab68
Jul 04, 2016 | Sony Bravia Kdl-40ex500 Series 40-inch Lcd...
Accent model ADC 27E1. Why is it displaying E C fault?
FAQs and Troubleshooting - Actron Air
www.actronair.com.au/service-and-warranty/faqs-and-troubleshooting
The air conditioner is not running at all and no control lights are on. (If there are no ...Air conditioner regularly cuts out on a circuit breaker trip or error code ...
Air conditioning (Accent Air control panel) is - Fixya
www.fixya.com/support/t3343544-air_conditioning_accent_air_control
Nov 3, 2009 - Air conditioning (Accent Air control panel) is displaying EC - what ... Panasonic mini split air conditioner css9nkua error code h99 what does it mean ...ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL .
Dec 05, 2015 | Heating & Cooling
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
WHY SMA SUNNY BOY SOLAR PANEL INVERTER SAYS ERROR F1-OPEN ?
I suspect strongly that it has an interlock switch on the front panel, and someone has opened the panel and failed to fully close it back up so it's weathertight.
Jul 31, 2014 | SMA SWR 700U SBD Sunny Boy 700W with LCD...
Sunna 3000TL inverter , red led light flashing ,
Unplug the inverter, and have the outlet tested. After being unplugged for a while, the inverter should reset when it is plugged into a grounded outlet.
Nov 26, 2013 | SMA Sunny Boy 6000US Inverter, 6000W,...
My Prosine 2.0 display panel displays Panel Fault: Memory error and the display error as well as all lleds are off. The unit looks as if it has no power to it. I reset (power off.power on) the prosine and...
This is a know and widespread problem with the Prosine 2.0, yet when you call Xantrex, they want to charge you to return, repair and/or replace the remote panel. Shame on you Xantrex.
Sep 06, 2010 | Xantrex Technology 806-1800 Prosine...
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
