Question about Apple LaserWriter 12/640 PS Plus Printer
Laserwriter 12/640 PS
Hi My old 12/640 Laserwriter has a "phantom paper jam", i.e., while starting up, it just picks up the paper, the motor runs for about 1 second and then stops ang gives a paper jam light. The problem seems to be known in the repair manual and refers to either a solenoid, a cable, a sensor and a board. BUT When that printer was hooked up to another puter, one could use it from the hand feed tray, which for me is enough. But now, whatever I do, it will, at power-up, try to print that test page and lock up. How can I, without the printer being hooked up to a computer, prevent it of wanting to print a test page ? Thanx, Takeo.
    Problem Solver:
  • 25 Answers
Hello the printer paper pick-up rollers are bad. this why you caanotuse the pick tray. the solution now is to set the printer to default and clear allstuff off memory. read the instruction below: LaserWriter 12/640 PS: IBM PC or Compatible Troubleshooting This article explains IBM PC or Compatible Troubleshooting. A message on the screen says the printer can't print. If you get such a message, try the following steps. Make sure that the printer is turned on. Check the network or parallel cables. Make sure that the PostScript printer driver has been installed. Nothing is printed; no paper comes out of the printer. If you don't get any response from the printer when you try to print a document, try the following steps: Check the Installed Printers list to see that your printer is selected. Try printing the document again, but choose Download PostScript Error Handling in the Printer Setup PostScript Options dialog box. Check the Paper Out light. If it is on, add paper and replace the paper cassette. If it is blinking, make sure the paper cassette is securely in place. Check for a paper jam. Check the printer cables. Check the position of the port communication switch. The port may have been turned off or the Interpreter settings may not be correct. Reset the communications settings to their factory default values by setting the communication switch to the Reset (out) position. Turn the printer off and back on again. Set the communication switch to the Normal (in) position. Turn the printer off and back on. Check the startup page. Reinstall the printer driver. For Windows 95 users, check the following additional item: Open the Printer folder, select the printer, and click Properties. click the PostScript tab and click the Advanced button. Make sure that ASCII data and "Send CTRL+D after job" are selected. For Windows 3.1 users, check the following additional item: Open the Printer Control panel, select the printer, and choose Setup. Select the PostScript tab in the Properties dialog box. Make sure that Protocol Options is set to Default if using the parallel port, or None if printing via NetWare. Sometimes Printing the First Page Takes Longer than I Expect The LaserWriter 12/640 PS automatically goes into an energy-saving mode after it's been idle for a while. When you print while it's in this mode, the printer takes about a minute to warm up before it can print the first page. The printer is properly connected and configured, but printing is garbled or displays unwanted characters. Check the communication switch and make sure that the Interpreter is set to the correct value. If you are printing a PostScript document, the Interpreter mode should be PostScript or AutoSelect.
Posted on Aug 11, 2007
SOURCE:
HP P3005d won't pick up paper unless tray is mostly full (phantom paper jam)
The problem could be related to the age of the machine. No matter what fix you try, it won't be permanent.
Apr 11, 2014 | HP LaserJet P3005n Printer
12/640 PS wont feed from tray
I found the owners manual for your model, and it has detailed explanations of how to turn off the printing of the Startup page: This is where the owners manual is available online in .pdf format, at this URL: http://download.info.apple.com/Apple_Support_Area/Manuals/printers/0340211ALW12640UM.PDF Startup Page Info From your Owners Manual: (Yes, I've been reading the Manual for your printer. I have no life. :P ) From page 25 of the manual: "The printer takes a minute or two to warm up, and then it automatically prints a startup page. It prints the startup page every time you restart unless you turn the startup page off using either the Apple Printer Utility for the Mac OS or the Apple LaserWriter Utility for Windows. See Appendix A for details on these utilities." From page 249 of the manual: "Appendix A - Setting the Printer Default Settings" "Though the printer itself has no control panel, you can configure it by using programs on computers connected to the printer: - On Mac OS?based computers, use the Apple Printer Utility and the desktop printer?s setup function." So the answer is YES, you CAN setup the printer to not print the test page, but you have to use the setup utility on your computer to do so. Opening the Apple Printer Utility (From page 251) "The Apple Printer Utility has two windows: the Printer Selector window, which is similar to the Chooser, and the printer features window, which you use to view or change the printer?s settings." 1. Double-click the Apple Printer Utility. - The Installer puts the Apple Printer Utility in the Apple LaserWriter Software folder. You can move it wherever you like. 2. In the Printer Selector window, select and open the printer you want. - If the network has zones, click the zone where the printer is located. - Click the name of the printer you want. 3. Click Open Printer. - The printer feature window appears with the Printer Information category displayed. 4. To view or change settings under a category, click the arrow beside the category name to open the category and display its information and options. - Additional options may appear that you can also open and work with. When you are finished changing options in a particular category, you can click the arrow again to collapse the options. (NOTE: The option you want is "Startup Page".) 5. After viewing the information and making changes, click the Send button to send your changes to the printer. 6. Click the Close box to close the window. Turning the startup page on or off (From page 257) "The LaserWriter 12/640 PS normally prints a sample page when you turn the printer on. This page shows the printer?s name, the total number of pages printed, the amount of memory, installed options, and communication settings. You can turn this feature off if you wish. 1. Open the Startup Page category. - The Startup Page panel appears. 2. Click the checkbox to turn the startup page on or off. - When an X appears in the checkbox, the printer is set to print the startup page. 3. Click Send to send the startup page setting to the printer. That should remove the default printing of your startup page. HOWEVER, there is another possibility to affect a repair to your problem... As the paper-feed rollers get older, the rubber on the rollers gets slick and won't grip the paper anymore. Try buffing the rubber rollers with some fine sandpaper and see if that allows the machine to pick the paper up once again. If this is your problem, then you might make the lower-feed paper tray work again. Hope this helps, but let us know if you need more information to solve this problem. ;)
Aug 07, 2007 | Apple LaserWriter 12/640 PS Plus Printer
Hp laserjet m3035 mfp does not take up the paper squeaks and reports paper jam - no papaer is jammed
The most common cause of this type of Phantom paper jam is worn pickup rollers and separation pads in the paper trays. When these rollers get worn the gripping surface can not grab the paper correctly so no paper is fed into the printer and the printer gives the paper jam error. The rollers are very easy to replace, it takes about 20 minutes total. Here is a link to more information about the roller maint kit:
www.ccl-la.com/catalog/product_info.php?products_id=172
Mar 18, 2013 | HP LaserJet M3035 MFP Printer
Paper jam
hi,
please clean all rubber rollers and pick-up rollers also. Also check the paper motor.
Jun 04, 2012 | HP Photosmart C5180 All-In-One InkJet...
PSC 2175 wont work with print server
Please make sure that the printer is working okay if directlysd connected to the MAC computer. You may try this as well. hope this helps
Description
LPR (line printer remote) is a platform independent printing protocol that is associate with TCP/IP. It works by using LPR client software that communicates to a server running LPR services.
In terms of PSU, LPR printing will become the basis for all network printing while Novell print queues are phased out. Therefore, all Macintosh, Windows, and Unix computers will be configured to print through LPR.
Requirements
· The name of LPR print queue. This can be found by searching the LPR printer database.
· LaserWriter print drivers version 8.5.1 or newer
· The Macintosh must have a working TCP/IP networking configuration. (If the Mac can browse the web then it's working.)
· a server running LPR services or a printer that supports LPR printing. Most HP LaserJet printers support LPR. However, only the following LaserWriters support LPR printing:
- LaserWriter 8500
- LaserWriter 16/600 PS
- LaserWriter 12/640 PS
- Color LaserWriter 12/600 PS
- Color LaserWriter 12/660 PS Procedure
1.Open up the Applications folder from the OS X menu.
2.Open up the Utilities folder
3.Now open up the Print Center
4.If you have no printers installed you will see the following screen. Click on Add.
5.On the following screen, select LPR printing.
6.Now enter printhost.oit.pdx.edu for the LPR Printer's address.
7.Uncheck Use Default Queue on Server option and enter the queue name of the printer.
8.Select the printer model.
9.The completed settings should be similar to the following:
(LPR Printer’s address is the ip of our PRINTSERVER)
10.Click on Add
11.Your printer has successfully been installed. Test the printer by printing something to it.
Mar 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Apple 16/600 Laserwriter reports out of paper but its not
It's the sensor from tray fault. Try to blow with air spray to sensor, maybe is dirt with paper dust and need clean.
All the best and Happy New Year !
Dec 29, 2017 | Apple LaserWriter 12/640 PS Plus Printer
12/640 Laserwriter - driver needed.
I had the same problem when I got a new computer with Vista. I just went through the available 600 DPI printer drivers until I found one that worked ok with the 12/640 printer. The driver I used was the Samsung 6000 PS. I have had no problems with it.
Nov 19, 2008 | Apple LaserWriter 12/640 PS Plus Printer
Won't print tabloid paper
I had this problem a couple of years back and took the printer to a service company. They replaced the paper pickup rollers and I have not had the problem since. Other problems, yes, but not that problem.
Aug 16, 2007 | Apple LaserWriter 8500 Printer
Open Questions:
See all Apple LaserWriter 12/640 PS Plus Printer Questions
Apple LaserWriter 12/640 PS Plus Printer Logo
450 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Alun Cox
Abdul Mannan
Abdul Mannan
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
