Question about Advanced Graphics Programming Using OpenGL
Source code plz plz plz giv opengl code for singly linked list implimentation
    New Friend:
Farm frenzy 2key
Posted on May 16, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: opengl code
OpenGL doesn't handle photonics or any other low-level physics - you'll either need a raytracer, such as POVRAY or Blender, or you'll have to write the physics yourself, to emulate light rays of varying colours (I recommend using a HSL colour space for your physics, only translating to RGB when rendering the frame).
The refraction of a ray at the interface of the prism and the "air" can be calculated using Index of Refraction, correction factor to account for different refraction dependent on frequency (Hue) and a random number generator to emulate slight scattering.
Posted on Sep 05, 2009
I have loss my web cam coftwere plz giv it to me
Download the Drivers for your camera from this link : ( download the last option in the list )
http://www.radioshack.com/uc/index.jsp?help=yes&page=software
Jul 03, 2010 | Radio Shack VGA PC Camera Webcam
I want a paint brush application using opengl
Pain.net is one of the best open source paint programs. You can download at the link below:
http://www.getpaint.net/
Nov 14, 2009 | Advanced Graphics Programming Using OpenGL...
I want a program in openGL for the paint editor
i want a mini project on opengl the topic is graphics ediotor jst like ms paint
May 20, 2009 | Advanced Graphics Programming Using OpenGL...
I need open gl source code to make a point move along the circumference of the circle.
Hi
 I'm studying Physics, not CS, but I've had a few brushes with OpenGL.
 I'll use a Basic-like pseudocode syntax since I don't know what language you're using, and basic is very easy to read:
'Constants - Radius is radius of the circle
Const PI = 3.14159, Radius = 10
'Current angle, and angular velocity (dTheta / dt)
Dim Shared Theta as Single, Omega as Single
'Frame is called when you want to draw a new frame
Sub Frame(dt as Single)
  'dt is number of seconds passed since last frame (typically less than one, since you want several frames per second)
 'Initialize the frame (clear buffers, set up projection, etc)
 InitFrame
 'Increase angle
 Theta = Theta + (Omega * dt)
 'Calculate co-ordinates of point
 X = Radius * Cos(Theta)
 Y = Radius * Sin(Theta)
 glBegin(GL_POINTS)
  'Set the colour of the point
  glColor(<r>, <g>, <b>, <a>)
  'Draw the point
  glVertex2f(X, Y)
 glEnd()
 'Display the frame
 RenderFrame
End Sub
May 16, 2009 | Advanced Graphics Programming Using OpenGL...
Opengl code
Apr 24, 2009 | Advanced Graphics Programming Using OpenGL...
Source code for for representation of dictionaries using linked list in C++
Nice try! Find an upper-class student to give you one-on-one tutoring with your homework assignment.
Oct 20, 2008 | Computers & Internet
Open Questions:
my code in opengl does not work can any one help me #include <string.h> #include <GL/glut.h> #include "math.h" float rotate =0.0; float start = 0.0; float z_dep = 0.0; int poi_size = 0; int poi_arr[100][2]; float rad_arr[50]; int m_x = 0; int m_y = 0; int rubber_band_on = 0; int down_flag = 0; #define MENU1 10 #define MENU2 11 #define MENU3 12 #define MENU4 13 #define MENU5 14 GLfloat r,g,b; GLint t=0 ; void sel(int item) { switch(item) { case MENU1: {r=1 , g=0 , b=0;} break; case MENU2: {r=0 , g=0 , b=1;} break; case MENU3: {r=0 , g=1 , b=0;} break; case MENU4: {t=1;} break; case MENU5: {t=2;} break; } glutPostRedisplay(); } void menu(void) { int MainMenu, SubMenu1,SubMenu2; SubMenu1=glutCreateMenu(sel); glutAddMenuEntry("red", MENU1); glutAddMenuEntry("bule", MENU2); glutAddMenuEntry("green", MENU3); SubMenu2=glutCreateMenu(sel); glutAddMenuEntry("line", MENU4); glutAddMenuEntry("circle", MENU5); MainMenu=glutCreateMenu(sel); glutAddSubMenu("Color", SubMenu1); glutAddSubMenu("Shap", SubMenu2); glutAttachMenu(GLUT_RIGHT_BUTTON); }void drawCircle(float radius, float x1, float y1) { float angle = 0; float x2,y2,cx,cy,fx,fy; int cache = 0; glBegin(GL_LINES); for (angle = 0; angle < 360; angle+=1.0) { float rad_angle = angle * 3.14 / 180; x2 = x1+radius * sin((double)rad_angle); y2 = y1+radius * cos((double)rad_angle); if (cache) { glVertex2f(cx,cy); glVertex2f(x2,y2); } else { fx = x2; fy = y2; } cache = 1; cx = x2; cy = y2; } glVertex2f(x2,y2); glVertex2f(fx,fy); glEnd(); } void tick(void) { glutPostRedisplay(); } void display1(void) { glClear(GL_COLOR_BUFFER_BIT); // Draw the lines created by user glBegin(GL_LINES); for(int i=0; i<poi_size; i++) { glVertex2f(poi_arr[i][0],poi_arr[i][1]); } if (rubber_band_on && (poi_size%2==1)) { glVertex2f(m_x,m_y); } glEnd(); glutSwapBuffers(); } void handleKeypress(unsigned char key, int x, int y) { switch (key) { case 27: //Escape key exit(0); } } void reshape(int w, int h) { glViewport(0, 0, w, h); glMatrixMode(GL_PROJECTION); glLoadIdentity(); gluOrtho2D(0, w, h, 0); glMatrixMode(GL_MODELVIEW); } void mouse_move1(int x, int y) { m_x = x; m_y = y; display1(); } void mouse1(int button, int state, int x, int y) { m_x = x; m_y = y; switch (button) { case GLUT_RIGHT_BUTTON: if (state == GLUT_DOWN) { // glutIdleFunc(spinDisplay); } if (state == GLUT_UP) { if (poi_size>0) { poi_size-=2; } rubber_band_on = 0; glutIdleFunc(NULL); } break; case GLUT_LEFT_BUTTON: rubber_band_on = 1; if (state == GLUT_DOWN) { down_flag = 1; } if (state == GLUT_UP) { if(down_flag) { poi_arr[poi_size][0]=x; poi_arr[poi_size][1]=y; poi_size++; down_flag = 0; } glutIdleFunc(NULL); } break; default: break; } display1(); } float calculate_radius(int x1,int y1) { int x_diff = m_x - x1; int y_diff = m_y - y1; if(x_diff<0) { x_diff *= -1; } if(y_diff<0) { y_diff *= -1; } float mag = x_diff*x_diff + y_diff*y_diff; float rad = sqrt(mag); return rad; } void display2(void) { glClear(GL_COLOR_BUFFER_BIT); for(int i=0; i<poi_size; i+=2) { int rad_index = (int)(i/2); float rad = rad_arr[rad_index]; if (rad>1) { drawCircle(rad,poi_arr[i][0],poi_arr[i][1]); } } glutSwapBuffers(); } void mouse_move2(int x, int y) { m_x = x; m_y = y; if (rubber_band_on) { float rd = calculate_radius(poi_arr[poi_size-1][0],poi_arr[poi_size-1][1]); rad_arr[poi_size/2] = rd; } display2(); } void mouse2(int button, int state, int x, int y) { m_x = x; m_y = y; switch (button) { case GLUT_RIGHT_BUTTON: if (state == GLUT_DOWN) { // glutIdleFunc(spinDisplay); } if (state == GLUT_UP) { glutIdleFunc(NULL); } break; case GLUT_LEFT_BUTTON: if (state == GLUT_DOWN) { down_flag = 1; } if (state == GLUT_UP) { if(down_flag) { poi_arr[poi_size][0]=x; poi_arr[poi_size][1]=y; poi_size++; down_flag = 0; rubber_band_on = !rubber_band_on; } glutIdleFunc(NULL); } break; default: break; } if (rubber_band_on && poi_size>0) { float rd = calculate_radius(poi_arr[poi_size-1][0],poi_arr[poi_size-1][1]); rad_arr[poi_size/2] = rd; } display2(); } int main(int argc, char **argv) { glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB); glutInitWindowSize(1000, 800); glutCreateWindow("OPENGL LINE DRAWING"); glClearColor(0.0, 0.0, 0.0, 1.0); menu(); if (t=1) { glutDisplayFunc(display1); glutReshapeFunc(reshape); glutIdleFunc(tick); glutKeyboardFunc(handleKeypress); glutMouseFunc(mouse1); glutMotionFunc(mouse_move1); glutPassiveMotionFunc(mouse_move1); glutMainLoop(); } if (t=2) { glutDisplayFunc(display2); glutReshapeFunc(reshape); glutIdleFunc(tick); glutKeyboardFunc(handleKeypress); glutMouseFunc(mouse2); glutMotionFunc(mouse_move2); glutPassiveMotionFunc(mouse_move2); glutMainLoop(); } return 0; /* ANSI C requires main to return int. */ }
Jun 22, 2013 | Advanced Graphics Programming Using OpenGL...
See all Advanced Graphics Programming Using OpenGL Questions
Advanced Graphics Programming Using OpenGL  Logo
473 people viewed this question
Top Advanced Graphics Computers & Internet Experts
David Payne
David Payne
Are you an Advanced Graphics Computer and Internet Expert? Answer questions, earn points and help others
