Hi, I purchased a new Pioneer VSX-816-K from amazon about 4 months ago. Has been working great. I have a Directv TIVO connected to it ( about 1.5 yrs old ) via S-video and Fiber Optic for Audio. This setup has worked well for the last 3-4 months now. However, specifically in regards to the Fiber connection - my sound is now randomly cutting out for about a 1/4 of a sec. I took a can of air and cleaned the ends of the fiber - didnt help. I Also get the cut outs when i play dvd's that has been going on for longer than the tivo issue.. My dvd sound is connected via Coax. I didnt think much of the dvd issue as its a quite cheap $40 apex. Right now i removed the fiber and i have it plugged in via composite l/r plugs.. its only been this way for 4 hours or so.. and so far its been ok... I play the XM sat radio stations.. so i should be able to spot it quickly. ITs odd that its doing it on BOTH the coax and the fiber.. The unit isnt heating up... its hot.. but nothing above usual ( at least to me ). Should i try and swap the fiber?... I would find it quite suspect/odd if BOTH my fiber cable AND my coax cable are bad. Again.. its only these two inputs that seem to be causing this.. i can put it on FM radio.. and play it all day no issues.. no cut outs. It is still under warranty with pioneer.. but its prolly gonna cost me 45-50$ shipping costs just to get it to them. Possibly a componant that controls both the coax And the Fiber may be overheating? thanks for the help - jb
I had the same issue with the front right speaker randomly cutting out. Thought it was a loose solder joint however upon taking it apart i found that something near the back panel was shorting out. While apart i found that wiggling the rear panel would cut in and out the speaker. Also the fan would turn on when the speaker worked, which until i took it apart i didn't know it had a fan. I removed the back panel by taking out several screw the hold the cable plug-ins. once the panel was out i insulated it with electrical tape then used a utility knife to cut out all the cable connector holes. I also took out a couple screws on the main board so i could lift it a bit from the back and ran electrical tape over the solder point for the speaker connectors. Put it back together and haven't had any cut out's since. I now notice that the fan now runs all the time exept when i press mute. I also hear a single tap noise for a second when i mute or turn off the receiver. I can certainly put up with that though. Hope this helps someone else, I put up with the speakers cutting out for 6 months before i got around to taking it apart. Also those bannana plugs are a rip off, I went to future shop to buy them and couldn't beleive they were 25.00 for two pair. That would mean it would cost me 75.00 to do my 5 speakers. Thats more than i paid for my dvd player. anyhow i didn't buy them and just used bullet connectors, pack of 10 for less than 5.00, not made of gold but they work fine.
My vsx 816 does the same thing months at a time its fine then the cutting out starts seems to be on front channels make sure you have 8 ohm speakers and not 4 that was one thing i had over looked rushing to connect everything.
All the digital (coax and optical) is routed to the DSP in the reciever. The analog is converted to digial (internal to the receiver) and also goes to the same DSP. One possible difference is there may be a intermittent connection internally (cold solder joint, connector pulling apart) from the digital I/O board to the DSP section. Your analog sources are working (tuner, analog audio inputs) so the DSP and on.. are probably ok.
My Pioneer VSX-816 sound cuts out, I have tried using different cables as well as different speakers. I still run into the same problem- while playing a game my speakers lose stop producing sound. After trying different configurations I have determined that the problem must be within the receiver, as shutting the power off then on again corrects the problem for a few seconds
My front left speaker is having a cut out / static issue randomly. I connected the front right to the front left jack and the front right began having issues, so I know it is the jack and not the speaker or the speaker wire. Don't know what to do. About to trash the thing.
I have the exact same problem as rberth. If I bang on the unit the left channel will start to work ant then cut out 10 minutes later. I did trash it and purchased a onkyo tx-sr606. I'm very happy with this AV receiver.
Yep! Same problem here. Left channel is cutting out randomly. A light tap on the unit brings it back on for a period. Only had this 14 months when it started. I love the receiver otherwise. Hate to buy a new one. Is it worth getting fixed?
I have the same issue. Great unit, about 16 months old. Recently started cutting out intermittantly. The Right front channel in my case. Happens mostly when volume is low. When it's cranked up just a little, issue goes away. I suspect some faulty power throughput component.
What a piece of **** Pioneer made with the VSX-816 AV receiver. Junk. Same problem with center channel sound cutting out. Doesn't anyone know of a fix other than the garbage dumP?
I have the same problem. Only had the unit for about a year and now randomly my front and left speakers will cut out. I have to turn it off and back on for the sound to come back. Its not my speaker wires because I just switched to banana plugs but the problem is still there. Pioneer is really garbage, i'm going to stick with SONY from now on.
