My LG WF-T8018TP top loader washing machine gives a PE signal and the water does noet want to run out. What is the problem?
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
I have a LG 3step Turbodrum Fuzzy Logic WF-T8018TP when I put on the auto/off button it keeps on showing me the error PE how can a fix this
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 14, 2015 | LG Washing Machines
Fault PE....How do I replace the pressure sensor on an LG fuzzy logic 5kg wf-t502 top loader and where can I purchase this part?
PE Means pressure sensor error this spares is very rare to defect 1st check full pressure sensor the wiring harness any damage or wire cut means the error will show in display
Mar 26, 2015 | LG Washing Machines
Hi ihave a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
You have a problem with the pressure switch (water level sensor).
Either a faulty switch, blocked air chamber or hole in the pressure hose linking the chamber to the switch.
Thanks
Jul 14, 2014 | Washing Machines
My LG WF-T8018TP Fuzzy Logic is not draining water
kindly check drain motor some forgot items are in side...
Feb 12, 2014 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
What is the problem if the LG Fuzzy WF-T1330TP top loader shows error code PE.
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
Apr 08, 2011 | LG Washing Machines
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
