Question about Kodak EasyShare C143 Digital Camera
Battery door replacement
REPLACEMENT FOR NEW BATTERY DOOR
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
You may order a green one from http://uscamera.com/c143.htm . The other colors seem to be unavailable.
Posted on May 02, 2013
If my battery went dead on my remote for my gagage door opener do I have to reprogram remote when I put in new battery?
WIth car remotes they do not need re-coding if the battery is replaced within a few minutes of the old one being taken out.
source: car remote battery sales assistant.
Dec 24, 2014 | Genie gict390-1bl new g3t-bx garage door...
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
How to replace battery door on canon a640?
I not completed this yet but I have the new door in hand. I got this from online.
Battery door replacement on this model will require removal of both front and rear case,fairly straight forward remove all screws and seperate case.You will see that door is kept in place by a small metal rod,which will slide out and allow defective door to be removed and new door to be installed(note location of spring before removing).
Apr 21, 2010 | Canon PowerShot A640 Digital Camera
Battery Door
Contact Canon at their website. Battery doors are a common replacement item and they're relatively inexpensive and easy to replace.
Oct 23, 2009 | Canon Photography
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Need to reprogram door locks for 2004 Toyota Camry
I recently replaced the battery on my 2004 Toyota Camry. When I installed new battery the door locks will not stay unlocked once opened with remote. How do I reprogram?
Feb 21, 2009 | 2005 Toyota Camry Solara
Nikon COOLPIX 3100 Digital Camera
I WOULD SUSPECT THAT THERE IS SOMETHING WRONG ON THIS NEW DOOR THAT THE BATTERIES ARE NOT MAKING GOOD CONTACT WITH THE DOOR AND THEREFORE NOT SUPPLYING POWER TO THE CAMERA. IF IT WORKED BEFORE THE DOOR WAS REPLACED, THERE MUST BE SOMETHING AT THAT POINT. I WOULD LOOK THERE FOR PROPER PRESSURE ON THE BATTERY OR BATTERIES.
Oct 31, 2008 | Nikon COOLPIX Cameras
Battery Door
remove two small phillips head screws next to battery compartment,,this will allow you to raise the camera case enough to insert the tabs from the new battery door cover,replace the screws,,,i just replaced mine not to difficult
Jul 15, 2008 | Kodak EasyShare CX4200 Digital Camera
Battery door doesn't close tight
Usually part of the plastic battery door breaks off so the sliding latch (when you push the battery door in toward the camera after replacing batteries) can't latch. If this is the problem you can buy a new battery door that will come with a new latch that isn't broken.
Jul 10, 2008 | Cameras
How to replace battery door?
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
Dec 12, 2006 | Canon PowerShot A20 Digital Camera
Kodak EasyShare C143 Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
