Zyxel G-5100  802.11b/g Wireless Access Point
Problem for Zyxel G-5100 (ZYAIRG5100) 802.11b/g Wireless Access Point
Connection to Access point periodically lost
By JohnnyL on Aug 08, 2007
I have a Zyxel G-5100 Access Point installed, and periodically the connection to the device is lost. When this happens, I can't connect via the web-interface or ping the device. When I turn the device off and on again, it works for a while again.
I have enabled logging and it is set up to send email when an error occures, but I never get an email after an error. Also, when I login to the web-interface after a restart, the log is empty, so there's no indication of what the problem is.
Same Problem
Mar 18, 2008
-   My organisation is using Zyxel B-5000,and we sometime we experience the related problem.Access point its unavailable sometime and hence users are unable to connect to it,but on reboot the adapter it becomes available and users are able to connect again.No error is displayed on its logs.Help please!
Bryan
makundib@udsm.ac.tz
-   Guest
Solution #1
posted on Aug 17, 2007
Somewhat Helpful)
PCguy
Rank: Wiz
Rating: 81%, 51 votes
I have recently gone through the process of setting up a wireless network in my home and I found that a lot of routers and access points 9especially in the wireless N and MIMO categories) have that same problem. Are you trying to go with wireless N? If so then you must be careful what you buy because cross brand connections are not always compatible and also most N routers on the market today do things like drop the connection for no reason. I would recommend the apple airport if you are looking for a good router in the N category. I know they are expensive, but after trying out 5 different routers including all the top brands, I came across the airport and haven't had a problem since. This issue you are having is likely a problem with the router itself.
Was this helpful?
Yes
No
Popular Solutions for Zyxel G-5100 802.11b/g
Questions and Unsolved Problems for Zyxel G-5100 802.11b/g
Do you recommend Zyxel G-5100 (ZYAIRG5100) 802.11b/g Wireless Access Point?
Answer
Answer
i am trying to pick up wifi on my i-touch pod , i have the2wire550 everytime the i-pod ask for my... (More)
Answer
i just got a gigabyte gn a11g access point. i plugged in my ethernet cable. when i tried to connect... (More)
Answer
when i turn on my computer it only works for 8 seconds and then it freezes again.
Answer
i have dlink AP 1353 model it stops connecting to the user and only allows to connect after... (More)
Describe your Wireless Access Points problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Wireless Access... Experts
Top Computer & Laptop Repairmen
in Windham, ME
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
