Question about Home
Fowler 4009 consort
Leaking sistern
The sistern is running al the time
If it is running inside flush then a washer at the inside bottom needs replacement. If it is overflowing the tree float valve needs change.
Dec 20, 2016 | Office Equipment & Supplies
I have a 1/2 Hp a.osmith **** for a well, it pumps up to pressure, turns off then continuosly pushes the water pressure out of the system within a minute or two then it turns on again? Check valve?
You didn't say which way the water was going. I am assuming back into the cistern and it that is so, yes, the check valve has failed or gotten full of trash. Change or clean it, might even be able to replace the flapper seal.
Oct 04, 2012 | AO Smith A.o. Smith T46056 7 1/2 Hp 3...
GASOLINE LEAKING OUT OF THE CARBERATOUR
Carbs need removing & the float jets cleaning, there is some debris stuck between the needle valve & the holder.
Easiest way to explain , it is like a toilet sistern float.
Sep 07, 2011 | 2003 Honda VT 750 C2 Shadow
My sistern gave me a brother printer DCP-130C I do not know how to open the paper tray looked everywhere i dont have a information booklet please help!!!!
I have a link to a website which will help you with the paper tray problem.
It is http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_DCP_130c_EN_294.PDF
This link is to a DCP-130C User's Guide. If any other problems arise, look through the guide.
Look on page 14 ( Loading Paper, Envelopes and Other Media ) concerning the paper tray.
If you don't have an installation disc, look at the site below for help.
http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=DCP130C
Feb 10, 2011 | Brother Office Equipment & Supplies
Water leaking inside toilrt bowl
The flush megnisems rubber has parished.
Step1. open sistern and locate the flush meganisem, [shoold 90% of time be the gajet in middel]
Step2.unhook or unscrew all the handels conected to it,
Step3. turn the meganisem left, it wil pop out and at the bottom after you pop it out u see a black rubber that looks damaged, go to plumbing shop with the rubber and they will give u 1 ,its cheeep.
that should fix it.
plz rate my advice
Jul 12, 2010 | Eljer Toilet Onepiece Canterbury ...
Push valve for urinal adjustment. How do we
HI im Rossouw
Most sisterns with 2 buttons 1 for urin 2 for bouls have have a button on top of the sistern
Remove the lid of the sistern by thast lifting it or unscrew the head of the bottem
After the lid is of iets easy, wear the arms are of the indevidual bottons u mist thast find the 1 u want to be urin and turn it right for less water and left for more water
Plz rate mt advice thanx
Jul 12, 2010 | Mansfield Plumbing Products Mansfield...
How to replace Caroma toitet suite outlet valve
Hello
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut and plz rate my advice, thanx
Jul 10, 2010 | Caroma 270W-RF Reflection Round Front...
The pump keeps running after flushing. Have to tap pump tank unit slightly to get it to shut off. Also from time of installation the water level in the bowl was and still is very low, any way to raise the...
hi keith
Bloues hear.
the water level in the boul is standerd to the manefactuer. the plumber cant help for that. if u put a level on ur toilet and iets level there is noting u can do about it.. the water that keeps on runing is ur seal rubber, its located at the bottem of ur flush meganusum. step 1.... tack off sistern aka pump. then step 2 ... unscrew your flush meganusem, will be the 1 in the middel of sistern. step 3 ... after unsrewing it u wil see there is a rubber. if the rubber looks fine then u must ajust ur flush meganisems arm or lubricate it. bt if rubber is misformed or teared ... u must go to a plumbing shop with the rubber. they will give u new 1 for cheap. and u can just reaplace it and esembel the sistern again
Jul 05, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
One of our EcoQuantum toilets really doesn't flush. It flushes part way, but only pushing the handle down; it does nothing pushing the handle up. We have to flush several times to get it to work. What do...
Hello
Im Rossouw. qwalifide plumber
Ur problem most likely is ur arm conected to your flush handel.
If the arm is iron, try bending it down so that when u use the handel it has more leverage tolift up ur sistern flush rubber and create a flow facume as we call it.
if its plastick.... u must ajust the hight of ur flush meganisem by turning the head were the arm is conected left and pushing it down and turning it right to fasen it again. this will also work for iron arm bt is un nessesery for iron arm.
ajust hight until problem is solved.
Please rate my advice thanx :]
Jul 02, 2010 | Dmm Mansfield 119CL EcoQuantum Toilet Tank...
I installed the 1.6 gal Maxima EL.\r\n I placed
Hi im Rossouw
put 4 clouse cuppels in today hehe
Step 1, place sustern on boul. tight it up and muve the sustern attached to the boul flush with the wall.
step 2, mark out were ur toilet will stand with a pensel, then remove pot and apply silicone to pot base [Remove sistern first lol] and to the floor were the pensil mark is
Step 3, ones ur pot is on the floor put ur sistern on. i think the leak you were refiring to is the spunge rubber in the middel of ur sistern, make sure that it is furmly over the thred on the out side of sistern were flush meganisem comes out and tight it all well down. check ur pot with a level and if it is let it dry over night and then u can use it
plz rate my advice
Jul 02, 2010 | Jacuzzi Bath Maxima EL61 959 White...
Home Logo
320 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
