Opening remote controller
I've to open it. I unscrewed the 3 little screws in the back ( near the 2 AA slots) but I'm unable to doing it apart...
  • 3,799 Answers
Is it a Laptop? Or even a computer?
Posted on May 01, 2013
SOURCE: How do I open the Samsun X15 to replace the power jack?!!! Help!
The power jack inside of the toshiba satellite 2455-s30x is NOT soldiered to the motherboard!! WOOHOO!! It actually sits on a set of rails. It easily slides out and is removed from the motherboard with a snap. Very simple and easy to replace. I know, because I have a 2455-s305 and mine just broke! I got it out, and was super happy to see that it is not a part of the motherboard. Now where do I get one?!?!
Posted on Dec 27, 2007
Nic61
  • 1073 Answers
SOURCE: Need help opening up back of Aspire 5570Z
Yepp, you need to separate the keyboard. You do that by remove the screw behinde the hinges. So dont pull out the screws under the laptop. When you removed the screws from the hinges, pull the keyboard up and backwards, be care, its all plastic and very very easy to breake.
Good luck
Posted on Dec 11, 2008
  • 180 Answers
SOURCE: Hi i'm trying to take
take all the screws off the bottom (including the screws hidden by the optical drive), turn the laptop over, open it. there is a small strip of plastic right above the keyboard, pry it loose and remove the 4 screws from underneath to release the keyboard. disconnect all the exposed ribbon cables and any other cable connector that you can see. once you've done this pick a spot on one of the edges to start prying it apart. Use a small screw driver or plastic pry tool if you need it. (on this model I started with the top right hand corner.)
Posted on Jul 02, 2011
Acadiemedia
  • 131 Answers
SOURCE: HOW do you open an acer one to access memory slot and hard drive?
Hi James, Here is a step by step video tutorial.
Enjoy your new upgrades.
Posted on Oct 23, 2011
jcrowder0846
  • 470 Answers
SOURCE: missing screw on bottom of Toshbia Satellite C655
Further reading of you posts tell me that there is a screw missing as you say so screws are needed to keep parts together. Without them inserted things are loose especially when doing the lid back and forth. It may make noises because of the missing screw or screws. "Replace" the screws that are missing. This should stop that noise.....John
Posted on May 13, 2012
How to upgrade memory
on the back unscrew the screws there are two places memory could be held take both of one wil be hard drive and other memory
if you have 2 slots put 2x2gbs
if you have 1 slot put 4gb memory in
let me know for further guidance
Mar 30, 2013 | Gateway LT4008u Atom N2600 Netbook
My 1998 Silhouette back door won't unlock with key or fob
follow the steps and fix it. God bless you
    • 1 Enter the passenger side of the vehicle and look under the dashboard, beneath the glove box and near the floor mat. With the aid of a flashlight, locate a large panel, which is held in place by screws. Unscrew the panel manually or use a screwdriver if the screws are too tight.
    • 2 Locate the fuse panel. The panel houses long rows of fuses mounted to the panel. Consult the vehicle's owner manual to determine which of the fuses controls the automatic doors
    • 3 Remove the fuse that controls the automatic doors with a pair of fuse pliers, or carefully with a pair of regular pliers. Examine the fuse by shining the flashlight close against it. If the metal bar inside the fuse is broken, the fuse has been blown.
    • 4 Replace the blown fuse with a fuse of equal amperage. Push the new fuse in place, confirming it is a snug fit.
    • 5 Test the automatic doors before screwing the fuse panel cover back in place. If the doors close automatically after you manually give them a tug, the problem was the blown fuse. Replace the fuse panel cover under the glove box.
    • 6 Test the automatic doors with your remote control. If they do not open or close, the problem is with the remote. Pop the rear cover off of the remote with a screwdriver and replace the battery.
Oct 18, 2012 | 1998 Oldsmobile Silhouette
Is it possible to disassemble the BN59-00851A Remote? I see only one screw under the batteries, and removed that, but the cover will not come apart. There must be some sort of screw or snap still holding...
I actually opened it!!!!!! You will need something super thin yet strong to get the
faceplate off pry upwards where the tabs are. I used a small screwdriver and chewed up the sides. hope you have a better way. after it is off it is easy to disassemble the rest. When putting it back on make sure the battery terminals get into their slots and just snap back on. good luck!9_29_2011_2_09_04_am.jpg9_29_2011_2_09_18_am.jpg9_29_2011_2_09_27_am.jpg
Dec 22, 2010 | Samsung BN59-00851A Remote Control
Not all the buttons work when you press them or they have to be pressed extremely hard
Hi:
This is due to dirty contact pads inside the remote, you can open the remote and clean the main board contacts and the keypad with some achohol.
Nov 09, 2010 | Toshiba Televison & Video
Craftsman Garage Door remotes do not work. 139.663953
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Hold the button down on your remote and press and immediately release the smart/learn button. Do this with all your remotes.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do i clean my tower aloha breeze fan
you have to remove the fan housing. it is usually screwed.
Sep 10, 2009 | Tower Aloha Breeze Fan
Morphy richards comfigrip 40715 how to disassemble?
Phil - I have the same problem. Can't see how to dismantle it at all. Did you ever get a solution?
Thanks
Chris
Aug 08, 2009 | Black & Decker AS975 Iron
Don't know how to replace AA batteries in Maglite AA.
they either unscrew from the back end or they unscrew from around the thick light end , then just pop in some new batteries making sure that they are pointed in the same direction
Jun 02, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Desktop pc slot
Unscrew the screw that holds the little piece of aluminum blocking the slot on the inside of the case.
Hope that I can be of help
Feb 04, 2009 | E-Machines (T2958) PC Desktop
DVDR 3460H - problem ejecting disk
1) Turn it upside down.
2) Turn it on
3) Press eject button & use screwdriver with special slot
Similar example
http://www.ryan.com.br/prod_dvp642_ejection.htm
Mar 23, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
