Question about Samsung MH080FXCA4A Free Joint Multi Ductless Outdoor Heat Pump 16
Heat pump flashing code E1
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
Codes
Flashing E-1 means your thermistor, a device attached to your thermostat that detects room temperature is shorted or broken. Replace or rewire thermistor. First turn power off to it. Second, clean air filter or replace if worn. Third, hit the reset button or scroll through menu until you find reset to factory settings. If no button or menu to scroll through unit then keep unplugged for 8 hrs to reset it. After that plug back in and power on and see if the e1 goes away. If not I recommend having it serviced. Also the owners manual is saying no pipe check operation check, try operating in auto addressing mode without pipe check. Sloution to check setting. Check piping connection and setting.
May 01, 2013 | Samsung MH050FXCA2A Free Joint Multi...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
I have a Bosch SHE56C05UC/40. The unit fills and drains ok but the circulation pump will not operate. I run the diagnosis according to another of you posts and came with an error code E1 which is a heating...
follow the instruction code in your ins.manual if you do not have go for free download : www. fitness.manualsonline.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Bosch SHE56C02UC / SHE56C06UC Dishwasher
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
E1 flashing on my telman washing machine
I found my manuel. It means somethngs stuck in the pump or pipes
Dec 03, 2009 | Washing Machines
E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Aug 05, 2009 | Dishwashers
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Samsung MH080FXCA4A Free Joint Multi Ductless Outdoor Heat Pump 16 Logo
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
