Question about Cell Phones
How to unlock 'key lock on' on LG32LH200H Flat screen without remote?
I don't have a remote control help me to unlock it without it!!!
  • 67 Answers
SOURCE: My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Posted on Nov 14, 2007
short shadey
  • 421 Answers
SOURCE: Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
Posted on Aug 31, 2008
bad_dog1
  • 104 Answers
SOURCE: drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
Posted on Mar 09, 2009
stevenhurc
  • 450 Answers
SOURCE: 2004 holden rodeo, remote control key wont lock/unlock doors
try putting key in ignition turn to on position
then press lock & unlock several times slowly if door locks cycle up & down after 1st press it lost code and is now resynconised.
now try remote with all doors closed and key out of ignition
if this dont work need to register key(program)back into system which dealer must do with Tech2 if round heart shapped remote
Posted on Jun 21, 2009
  • 521 Answers
SOURCE: 2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Posted on Aug 13, 2009
Toshiba backlight problems?
Without a remote control, you can't enter its service mode to unlock it. Try to get an original remote control. Contact the authorized service center.
Jul 01, 2013 | Televison & Video
RCA tv locked off. Don't have remote.how can I
You can't unlock it without remote control.
Mar 26, 2013 | Televison & Video
My problem is that key remote control works only very close to the car i change the battery still the same problem i don't have a spare key to test also petrol door lock and unlock not working wit
Your keyless remote is equipped with 2 different systems. There is the RF system (long range, lock control only) and the IR system (short range, locks and convenience features such as remote window roll-up and roll-down). It sounds like your RF system isn't working. The only way to test the system, that I know of, is with a Mercedes scanner. It is likely a bad remote.
Feb 02, 2013 | 2001 Mercedes-Benz C-Class
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
Locked rca tv and don't have remote
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 14, 2012 | RCA Televison & Video
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
How to turn off the parental control on my LG 42 in. HDTV LCD Television?
Look for any option in operation manual. If it is not listed there, there is now way!
Jul 30, 2012 | LG 42LC2D 42 in. LCD HDTV
Cant unlock pin number jvc LT-32DR1BJ
Instructions
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language
Jun 27, 2012 | JVC Televison & Video
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
