Question about Pool & Spa
I have a hayward north star pump, it starts and runs fine but, when I shut it off water comes up from the lid , I just replaced the o ring about 2 weeks ago. Any ideas
  • Alejandro Gonzalez May 03, 2013
    i fixed it ,thanks, it was the lid,
Being you have replaced the o-ring I would say to make sure you purchased the right o-ring the Northstar pump calls for there are 3 listed for it part #'s SPX4000S there is not a hair line crack in the lid itself if this checks I would suggest buying a tube of Jacks Lube take the o-ring off put a small amount of lube on it this will help it seal a little better
Posted on May 08, 2013
  • 93 Answers
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
Posted on Jun 18, 2009
john224
  • 1378 Answers
SOURCE: new hayward 1 HP super pump runs 1 or 2 seconds,
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Posted on Jul 04, 2009
  • 990 Answers
SOURCE: my hayward northstar pump makes a loud noise when
If you have a crack in your basket you may have a clogged impeller. With the power off reach back into the pump through the pump pot with a long screwdriver and feel around. If it feels spongey it there you have a clog. Take the serew driver an use an oceleting motion in a counter clockwise direction this should loosen the clog then reach in with a long set of thin pliers and pull the clog out. This should fix your problem and once water is flowing your pump should quiet down.
Posted on Oct 03, 2009
thepool
  • 78 Answers
SOURCE: Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
Posted on Apr 22, 2010
  • 8404 Answers
SOURCE: My Hayward Super II Pool Pump isn't priming. The
I think your impeller may be stuck OR your start capacitor has failed. Your pump is going off on over load because it cannot turn or cannot start.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
Closed and opened shut off valve to strainer housing basket, no water in strainer, how do you know if shut off knob actually opened or just broke the knob?
if the basket fills with water once you open the strainer lid then the valve is opening properly. If you open the valve and the strainer lid but you see no water flowing in then you can believe that the valve is not opening and needs to be fixed or replaced.
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
PINNACLE POOL PUMP SHUT OF DUE TO POWER LOSS THEN CAME BACK ON ALSO IMMEDIATELY NOW PUMP RUNS BUT NO WARE PUMPING
Fill the pump pot with water and make sure the lid o-ring is lubed and in good condition. Replace the lid and turn the pump on. If it still won't prime make sure the water in the pool is high enough. Otherwise you make have a suction side leak. Any breech in the plumbing will allow air to enter the water stream. If the breech is big enough no water will be drawn to the pump.
Oct 18, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
Mi pool pump is not pumping the water
In order for a pump to work it needs to be "primed" that is filled with water, the pool has to be up to the correct level, and nothing blocking the water flow. Hayward pool pumps also have many problems with their pump lids, they don't seal and let in air. They recommend using jacks lube on the lid o-ring but honestly Ky jelly works best. Hope that helps.
Nov 22, 2010 | Hayward Pool & Spa
I clean the filter cartrige and replaced it .then i turned on pool pump and then went to skimmer and added my d.e about 6lbs just like it calls for.then the oulet lines in the pool started to release all...
First number two. Your filter is just full of water and without air in the system it will look like their is no water moving through filter. As the filter get's dirty it will be harder to move water and start to cavatate so you will be able to see the air and so the water.
When you opened the filter to clean it you probably didn't get it sealed when you put it back together Try cleaning and lubing the "O" ring or replacing it. Also check the inner support ring if you have one and be sure it is in place. Check the tank when running for water leaks to see where air is getting back in when off. If you can't see any you may just need to run for a while and let some DE get into leak and seal it, if it is small enough.
Oct 03, 2010 | Hayward Pool & Spa
My pool pump will run fine once I prime the system from the top of the pump basket. Then once the timer shuts the pump off, when it trips the switch to run again there is no water in the pump and it cannot...
If you are a long way above the surface of the pool and you have a leak on the filter it could be a check valve problem.
With it competly loosing the prime it sounds more like a suction leak. This will be in the plumbing and will need a re-plumb or it could be as simple as a lid "O" ring or cracked lid.
What happens is the air get's in the tank and air will compress when under pressure. Then when the pump shut's down the air can expand again. When it does it will rush back through the system and blow the prime right out of the pump. Quite often you will see water blow out of the skimmer or just blow the skimmer lid off. I hope this helps. Good luck.
Sep 09, 2010 | Tristar Hayward 15 Hp Inground Swimming...
The filter wont vacumn
The filter is most likely not the issue at all.
When you lose vacuum pressure and see bubbles the problem is usually air getting into the line killing the prime. The most common place that air gets into the line is from the strainer cover on the pump. The clear lid on the front of the pump has an o-ring that is probably due for replacement.
With a bad o-ring it's easier for the pump to draw air through the lid then water through 20+ feet of vac hose. Replace the o-ring, make sure it is lubed well with a non petrol based grease.
The only other issue that may cause this is a cracked or seriously warped strainer lid, which should be easy to recognize once it is removed to replace the o-ring.
Once this is done you should be fine.
Oct 06, 2009 | Hayward SAND FILTER, PRO SERIES
I can not get vacuum pressure on my Hayward Sand Filter. I am using the Aquabug auto vacuum(which I've used over the last three seasons). When I fill the hose and put it into the skimmer port, I lose...
When you lose vacuum pressure and see bubbles the problem is usually air getting into the line killing the prime. The most common place that air gets into the line is from the strainer cover on the pump. The clear lid on the front of the pump has an o-ring that after 3 years is probably due for replacement.
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
Water keeps coming out from under the lid of the pump
Replace the O-ring/re-lube it, if that doesn't work the actually strainer assembly may be warped, those come undone with the clip under the basket and just pop off - they are between $80-$100.
Jun 28, 2009 | Hayward Powerflo Matrix 1 - Hp Above...
HAYWARE POOP PUMP
The pump should not shut itself off unless you have one of the newer 2 speed 2 phase pumps witch has its own proming mode. However a reason for loosing prime can be a simple pump lid O ring. It can also be the valves on the intake side of the pump. Try getting the pump going and the switch it off look and listen for leaks or air leaks you can either replace the needed O ring or apply 100% silicone to the leaking area with the pump on and that will seal the leak. Leave the pump running for 8 hours if using silicone. First start off by lubing the pump lid O ring you can use Vaseline.
Jun 25, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
Pool & Spa Logo
21 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
