Question about Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P)
Dell 0140 error code
No hardware detected. Will not boot up and stay on.
3 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: how to disabled the USB port of DELL inspiron 1200?
USB ports can be disabled in the bios.
Robert
Posted on Sep 21, 2008
ramminnathan
  • 71 Answers
SOURCE: error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Posted on Feb 19, 2010
Black screen with boot error
You should use your hdd with the operating system installed as 1st boot device; else, use the factory restore from your manual, it is a complete backup of your OS to application that is stored in a hidden partition in your hard disk.
Aug 09, 2013 | Dell Vostro 1500 Notebook
My xps m1330 booths up stays on for like 20 to 30 mins. then shuts off. After it shut off if i press the power button it willbooth back up again but this time it will shut off in within 5 to 10 mins. I get...
Sounds like the fans need cleaned or replaced. If the board and or the processor get to hot they may actually throw an error code. Try cleaning it and making sure the fans are moving.
Aug 25, 2017 | Dell XPS M1530 Laptop
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Dell inspiron p10f001 no booting 7 time beep coming
Seven beeps indicates a general exception error. This AMI beep code could be caused by an expansion card problem, a motherboard hardware issue, or a damaged CPU. Replacing the faulty hardware usually fixes the cause of this beep code.
Apr 17, 2012 | Dell Computers & Internet
Error code 2000-0141 no drive detected
That error code references a bad hard drive. If you still have warranty call Dell support line as that code means Dell will ship you a new hard drive.
Other options are much more complex like booting to a utility (you have to buy this) which will scan your hard drive sector by sector and try to repair bad blocks.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
After turning on it won't boot up past the "Dell" screen
You can check the hardware in the computer. by doing the self assesment.
1. turn off the computer.
2. At the Dell logo screen, press <F12>.
3. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
4. Write down any error codes listed.
Click Here to see the error codes listing.
Aug 17, 2010 | Dell Inspiron 1000 Notebook
After windows sp2 update
0141 error is no hard drive detected. So boot to the BIOS F2 at boot and ensure that the BIOS is seeing the hard disk drive. If it is not, then reseat the drive/drive cable connections and try again. If the drive is detected in bios, then try booting to WIndows, if HDD never is detected, reset bios defaults and reboot, and see if it detects, if still not detected, replace the hard disk drive
Nov 01, 2009 | Dell XPS 420 (dxcwqj1_2) Intel Core2 Duo...
Same proble, MS BitLocker is error message.
Bitlocker is available for Vista Business, Enterprise and Ultimate. This gives more security to your data files against unauthorized access. Once bitlocker detects theres a major change of hardware, such as master boot record, motherboard replacememt and such, it thinks that the hard drive is moved to another computer. Usually, bitlocker encryption can be disabled using the USB drive that was used to store the codes for decryption.
Jun 07, 2009 | Dell Inspiron 1501 Notebook
Hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Dell Inspiron One 2305 Desktop Computer (AMD Athlon II X2 GB3GB) (DDPCEZ1P) Logo
98 people viewed this question
Alun Cox
