Our eyes burn and get watery when we are sitting in the same room with the unit. We only use the unit for heating, and the filter is clean. We are starting to feel like we should not use it anymore...it is only 3 years old...not a very good investment as it now stands. We notice this particular model has been discontinued...I fear this is related to this problem.
What unit is it? If any appliance is making you sick, or causing you harm in ANY way, do not use it under any circumstances, please.
It might be a lack of humidity in the room though I expect the root of the problem is either a lack of good maintenance or bad original installation or a combination of both.
The fact the model has been discontinued is meaningless and I think you should contact a good maintenance engineer to check the unit and provide a report before you make any decisions.
SOURCE: Unit will not operate
http://www.fujitsu-general.com/global/products/index.html
Find your manual and check the code of the blinking green light. It will give you the resolution for your code. If you still have issues, post a comment back on this thread and I will be able to help you. You will need your model number for the website.
SOURCE: Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Your AC unit should be still covered by warranty, get the installer to check you AC unit.
Medical eye
wash can be really useful for relieving irritation, burning and itching, caused
by infections, allergies or foreign material in the eye. Rinsing with the
solution can ease the symptoms.
