Question about GE Microwave Ovens
Water damage to microwave
I was cooking in my pressure cooker today and the plug popped off (not the valve or the lid, a little plug on the lid) and soaked my whole kitchen, especially the over the range microwave. I cleaned it up, let it dry and all seemed well until I tried to heat something. The lights work fine (both inside and the under-lights), the fan, the rotating plate, screen... everything is fine it's just that it will not heat up and it was working just fine prior to this incident. I have a GE JVM1540DMBB and it's 4 years old. I was wondering if it could be something simple or if it's something major; don't want to fix it if it's cheaper to buy a new one. Thanks
    Top Expert:
  • GE Master
  • 42,687 Answers
There is a small sensor in the micro wave that controls the heat. You probably got water on the connections and shorted it out.
Posted on May 01, 2013
  • 4 Answers
SOURCE: GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Posted on Dec 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: metal pot
The magnetron may have gotten overheated. This could very well shorten its life.
Of course one should never leave a microwave unattended while it's running, but this rule is even more important for this oven now.
I would just use it as normal but keep an eye on it. If it clears up, good news. If it gets worse, then please reply back and let us know what your new symptoms are.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
  • 21 Answers
SOURCE: Microwave not working, please suggest
Your magnetron tube has failed. According to the warranty on the Profile Series microwave ovens, the magnetron is covered for 5 years from the date of purchase, but labor is not included. I would call GE Customer Service and when they ask for the model number (which begins with JVM) and the serial number, be sure to give the date of purchase as the date you closed on your house. If they insist upon charging you for a service call and labor, I would call my builder's Customer Service Department and demand (very nicely) that they intervene with GE to waive the service and labor charges. That worked for me (Lennar Homes).
Posted on Aug 07, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: suction fan on GE over-the-range microwave
If the blade is not big enough, the motor not powerful enough, or the vent size is wrong then it will not work properly, On thing you can do is check the vent cap and make sure that it has not falling down onto the vent pipe and blocking air movement.
Posted on Feb 11, 2009
EwingElect
  • 276 Answers
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Posted on Mar 25, 2009
I need a manual for the cooks essential pressur cooker # 99700
IF YOU HAVE INTERNET ACCESS, TYPE IN THE NAME OF YOUR MICROWAVE AND MANUAL AND DO A WEB SEARCH! COOKS ESSENTIAL PRESSURE COOKER MANUAL FOR MODEL NUMBER 99700
YOU'LL FIND MORE INFORMATION THAN YOU'LL PROBALLY NEED, BUT YOU WILL BE ABLE TO DOWNLOAD THE MANUAL AND SAVE IT OR ATLEAST FIND OUT HOW TO CONTACT THE MANUFACTURER TO HAVE THEM MAIL YOU A MANUAL!
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Microwave Ovens
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
I need the recipe for cooking rice in Crystalia Steamer/Rice Cooker
The general rule for cooking rice whether its in a rice cooker or a deep pan is to rinse the rice three times, put the same amount of water in the cooker (1 cup water to 1 cup rice). Turn on the cooker, let the rice cooker complete its cycle. Let the rice sit in the cooker for 10-15 minutes to steam. Serve.
You can vary the amount of water depending upon whether you want drier or moister rice. Enjoy.
May 30, 2011 | Microwave Ovens
Cook's essential pressure cooker has an E4 error. Tried everything and cannot get the unit to start
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Apr 23, 2011 | Microwave Ovens
I bought a refubished pressure cooker there is something funny the presure release device sits to loosely on top I wonder if its broke? Or where can I get a new pressure release device to replace this...
It should rattle if it is a pressure cooker This item will be round and should have a hole
in it. steam will escape from this hole as its cooking and it will rattle. It is a weight.
If it is a pressure canner it will have two items,
a pressure relief and a pressure gauge. Many had wing nuts which held the
lid in place such as mine has.
Wikipedia has a nice treatise on pressure canners as a reference.
hope this helps.
Mar 05, 2011 | Microwave Ovens
Have a used cooker-no instructions. What pressure/for how long to cook stuffed peppers?
Hi. 15 psi for 20 minutes. Here is the recipe STUFFED PEPPERS Printed from COOKS.COM
1 lb. hamburger
1/2 c. uncooked rice
Onion
Onion salt
Garlic salt
Celery salt
Tomato sauce
Green peppers
Combine hamburger, rice, onion, seasonings, and a half can of tomato sauce. Stuff mixture into peppers loosely. Dot with butter. Pour remaining tomato sauce over pepper. Place in a pressure cooker. Pour water in to almost cover peppers. Pressure cook for 20 minutes.
Jun 24, 2010 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
No homegrown popcorn in a microwave? why?
Popcorn is a food that has a very low moisture content, and microwave ovens rely on moisture content (water molecules) in order to cook.
If there is not enough moisture to absorb the microwave energy, much of the the energy is reflected back to the magnetron and damage it.
This is also what damages a microwave when it is run empty.
A simple solution is to add about 1/2 to 1 cup of water in a microwave-safe container in the back corner of the oven and cook your popcorn a little longer.
You'll have to experiment a few times to get the combination right for your particular model.
But allow our microwave about 15 minutes or so for the magnetron to cool down between popcorn cooking sessions.
Also, I would suggest putting a paper plate upside-down on the turntable tray, then putting the popcorn container on top of that.
This does two things: It keeps the extremely hot popcorn off the tray, reducing the chances it will crack, plus it raises the popcorn up so it will heat more efficiently.
Dec 23, 2008 | Microwave Ovens
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
Microwave Ovens Logo
67 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
