Question about Korg D888 8 Track Recorder
Here is a HOWTO for KORG D-888 hard drive replacement
I recently (and successfully) replaced the HDD in my D-888. I found nothing online so I wrote a HOWTO. You're welcome to use it. You can find the document at http://rishnet.com/HOWTO/D-888_HDD_REPL_HOWTO.PDF
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
I plug the USB from the D888 to my laptop (Toshiba Satelitte with Windows Vista) and nothing happens. The USB button is turned on.
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
Mar 23, 2013 | Korg D888 8 Track Recorder
I have a old (but almost unused) Korg d1200 recorder. Recently started getting disc error messages. Followed manual instructions to check disc drive and still get same results. Powered it up just now to...
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Jun 17, 2011 | Korg D888 8 Track Recorder
Want to replace my korg triton lcd touchscreen.where can i find a new one?
You will have to go to Korg to get the replacement screen.
Here: http://www.guitar-parts.com/catalog/korg/korg-touch-screens-lcds
Wow ... $300... ouch...!!!
Mar 30, 2011 | Music
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 | Korg X5d
KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
May 15, 2010 | Korg Pa800 Synthesizer
MR-1 cannot be mounted via USB
I cannot connect my Korg MR1 to my computer MSI wind with Windows XP via USB port. The computer does not see the hard disk
of the Korg MR1
Jan 19, 2009 | Korg Mr1 Digital Mobile Recorder
Korg D888 8 Track Recorder Logo
132 people viewed this question
Top Korg Music Experts
Vito Vacirca Jr.
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Korg Music Expert? Answer questions, earn points and help others
