Rca How To Set my RCA LED32B30RQ - 32"from 480i to 720p
No options to set it to 720p,it'll only display 480i
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
Refer its user manual. It must have details, if there is a facility to change the resolution.
Posted on May 01, 2013
5 Suggested Answers
  • 102 Answers
SOURCE: Need a users manual for a RCA 42'' diagonal 1080P LCD HDTV.
Hi here is a link to the manual for your tv. please rate me i need 3 more to get my badge thank you
Posted on Feb 02, 2010
  • 5 Answers
SOURCE: i need to set up
try checking this website. http://www.scribd.com/doc/2218751/RCA-Universal-Remote-Codes.
Posted on Jul 06, 2011
swapnesh_pan
  • 7 Answers
SOURCE: vizio hdmi blacking out when displaying PS3 in 720p
in these case hdmi technology is new then ps3 you will use the hdmi or usb display mediator for ps3
Posted on Feb 09, 2012
gopakumarg43
  • 75283 Answers
SOURCE: help setting up RCA hdtv to digitil cable
What type of help?
Posted on Aug 30, 2012
Onlly playing jn 480i
Roku only supports 720P and 1080P along with the Standard Definition. If your TV only supports 720i, then the Roku won't be able to display 720i but instead 480i which is the standard display that Roku can do on a TV that doesn't support 720p or 1080p
Aug 06, 2012 | Roku XD Streaming Player 1080P Wireless-N...
I'm running 720p on my 360, because it's clearer than the 768p PC Mode. But 720p Overscans the picture which makes it larger. Any way to fix this?
If you are using the Component Cables make sure the switch on the cable(part that you insert into Xbox 360) is set to HDTV and not TV because if its set to TV, no matter what resolution you choose it will go back to 480i.
If your using HDMI cable make sure that your TV is also outputting at an HD resolution. Like okay let me explain this more clearly I'm not sure on Sony HDTV's but we have a 46" Sharp Aquos HDTV LCD. I found out that the TV itself was still set to output at 480i even though the Direct TV receiver was set to HD so I went to my TV's options and changed to output the TV at 1080i then after that everything was clear because both the receiver and the HDTV was outputting at HD.
That maybe your problem. If your 360 in the settings menu is saying its at 720p and your TV still looks long, maybe your TV's Zoom options are set to Stretch or Zoom, so basically you need to change your TV's options to output at Normal.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How do I get my set out of HD mode?
You cannot get the TV out off what ever resolution it is being fed with, 720p in = 720p display (HD), 480i in = 480i display (non HD).
The video signals dictate the resolution TV display.
May I ask what kind of problem you are having?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Please leave rating if it helps.
Feb 02, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I need directions....my tv is set on 480i at the moment
The resolution of the TV is set by the source it is being fed with, just like your PC monitor which is set by the PC video card resolution. 480i = 480i display, 720p in = 720p display.
Its your the video source.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 30, 2010 | Televison & Video
720p is putting out signal of 480i or p only
Your Tv has its own settings for high definition.
Look in your manual for appearance setting and turn the tv to 720p high definition.
That should be enough. OH! And make sure your PS3 is set for HD output too! My HD tv downconverts occasionally when the Uverse box shuts off and defaults to low def output.
Feb 03, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
How to change from 480i to 1080i
The TV has a automatic scalier chip installed so it depends on the input signal that you are using. For example you are using a HDMI connection with a xbox 360 and you set the display setting to 720P then the TV will display it in 720P. If you set it to 480P then it will display it in 480P.
Apr 01, 2009 | ViewSonic N2635w 26 in. LCD Television
How to get 1080 resolution from my plasmaI have the 6842 pe EDTV
DVDs are 480p
HD-DVD or Blu-Ray DVD is 720p or 1080i or 1080p
you cannot increase resolution, if you want to play a 480p/i video on a 1080p/i or 720p screen, you are merely stretching the picture.
If there is any kind of box that tells you it can convert 480i/p to 1080p/i or 720p(high definition) it is simply stretching the picture.
you can convert 1080p/i or 720p(high definition) to 480i/p as you are taking out information from the video to make it smaller.
Feb 25, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
