Question about Compaq Presario 420 ac
Mac address how to find mac address
Blank wan mac address
You can't telnet based on the mac address you would be using the ip address. The mac is burnt into the device and isn't touched by a firmware update. If you did an update and the ip address changed, you can use a port scanner such as nmap to do a ping sweep and find the devices ip address.
Nov 17, 2013 | Computers & Internet
Trying to get xbox live but it states 'MAC' address, what is MAC address please?
A mac address is a unique code which identifies a piece of hardware. Sounds like your router is set up to only allow access to hardware that it has a mac address for, known as 'MAC address filtering'.
You could turn it off via your router's setup page, but it is there to provide an extra level of security, so it's best to leave it on.
You can find your xbox mac address by following these instructions
1. Navigate to the System area of the Xbox Dashboard.
2. Select 'Network Settings'.
3. Select 'Edit Settings'.
4. Select 'Additional Settings'.
5. Select 'Advanced Settings.'
The MAC address will be displayed toward the bottom of this page where it says 'Wired MAC Address'.
Feb 05, 2011 | Microsoft Computers & Internet
How do i find out what my mac and ip addresses are?
Windows XP
  • The host name is your computer's name
  • Click the Start icon
  • Click Control Panel
  • Select Classic View
  • Click Network Connections
  • Right click on the connection you are trying to find the MAC address for and select Properties - you will have a separate MAC address for your wireless card and your Ethernet (LAN) card. Make sure you use the correct one.
  • Hover your mouse over the text box underneath connect using. Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your computer on AU network you will need to register this MAC address
Apple Mac OS X (Tiger)
Information Services does not provide support for the use of Apple Macs. However you may find the following instructions useful if you wish to use your Apple Mac on our network
  • From the Apple in the upper left hand corner choose System Preferences
  • Click on the Network icon
  • From the Show menu Select Airport (for Wireless) or Built in Ethernet (for Wired)
    • For the Built in Ethernet (for Wired) the MAC address will be at the top of the Ethernet tab as the Ethernet ID.
      The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
    • For the Airport (for Wireless) the MAC address will be at the top of the AirPort tab as the AirPort ID (or on the TCP/IP tab, again as the AirPort ID ). The MAC address is the 12 character address e.g. 00:14:67:F0:56:A4
  • To find your Computer Name go back to System Preferences and click on Sharing , your computer's name should be in the computer name box at the top of this window.
Apple Mac OS X (Snow Leopard/Leopard)
  • Select Ethernet for Wired or Airport for Wireless
  • Click on the Advanced button
  • Click on the Ethernet tab
  • Your MAC address will be at the top of this window as your Ethernet ID . The MAC address is the 12 character address e.g. 00:11:22:AA:66:DD
Linux
  • In a privileged terminal session type: ifconfig
  • This will show you a list of the network adapters installed. The MAC address is referred to here as the HWaddr
  • If you have a wireless card you will see more then one MAC Address, make sure you register the right MAC address.
  • To pick out your wireless MAC address type: iwconfig - your Wired one will be the other one
Vista
  • Click Network and Sharing Center
  • Select Manage Network Connections from the list on the left hand side
  • Hover your mouse over the text box underneath connect using . Your MAC address will appear in the tooltip and is made up of 12 characters e.g. 00:11:22:AA:66:DD
Windows 7
  • Select Network and Internet
  • Select Change Adapter Settings from the list on the left hand side
    You will have a separate icon for your wireless card; your Ethernet (LAN) card and your Virtual WiFi MiniPort adapter (if you have one), each with their own MAC address. Make sure you select the correct one.
Nokia mobile phones
  • On the home screen, enter *#MAC0WLAN# or *#62209526#
  • Your MAC address will appear as a popup and is made up of 12 characters e.g. 00:11:22:AA:66:DD
To use your phone on AU network you will need to register this MAC address
http://whatismyipaddress.com/
You can use this link to find out your IP address
Good Luck
Dec 06, 2010 | Computers & Internet
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
Nov 04, 2010 | Computers & Internet
2 routers, same WLAN MAC addresses.
Hello Sailorgreg,
mac addresses are supposed to be unique addresses for each and every wireless network device.
There is no way to change or modify a mac address as it is programmed into the actual network adapter.
If you have purchased two different routers and they have the mac address for both, I would recommend trading one of them in because this would be a defect.
Thank you,
Pat
Mar 26, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
How to change mac address?
Every Ethernet card has a MAC address burned-in at the factory. At times, you may want to change this MAC address to one of your own choosing.
The procedures to change a MAC address are specific to each operating system.
How to change a MAC address in Microsoft Windows Under Windows, the MAC address is stored in a registry key. To change a MAC address, find that key with `regedit` and change it. Of course, Microsoft keeps moving the location of the key around!
Windows XP adds an option to change the MAC address on some network cards under the Advanced tab in the network adapter's Properties menu.
A much easier and more reliable method to change a MAC address under Windows is to use a software utility program designed to do this for you.
Macshift is a free utility that you can use to spoof your MAC address under Microsoft Windows.
How to change a MAC address in MacOS Instructions for changing the MAC address on a Macintosh can be found at MAC Spoofing on the Macintosh.
How to change a MAC address in FreeBSD In FreeBSD, you can change your MAC address with the `ifconfig <interface> link <address>` command.
How to change a MAC address in Linux Under Linux, you can change your MAC address with `ifconfig <interface> hw <class> <address>`, or you can use the GNU MAC Changer.
How to change a MAC address in Solaris In Solaris, you can change the MAC address with the `ifconfig <interface> <ether> <address>` command.
How to change a MAC address in OpenBSD OpenBSD does not, by default, allow you to change the MAC address. It is possible to change the MAC address under OpenBSD with sea.c.
How to change a MAC address in HP-UX Under HP-UX, you can change the MAC address in SAM by selecting Networking and Communications, then selecting the interface, then Action, Modify, Advanced Options. HP-UX refers to the MAC address as the "station address".
Changing a MAC Address in Hardware Speed Demon Adapters sells network cards which give you the ability to change the MAC address stored in their EERPROM.
This can give you the ability to change your MAC address under any operating system that supports either the PCI bus or PCMCIA Type II cards.
Feb 12, 2010 | Linksys WAG200G Router
Adding ipod touch to wgr614 network
In MAC Address binding, you should put the actual MAC Address of the iPod not the IP Address, they are different. Normally the MAC Address of the device can be seen on the sticker at the back of the device. Another way to identify the MAC address is go to Menu/Settings of the device and look for Device/System Information. MAC Adress usually have 12 hexadecimal characters (6 pairs). Now locate the MAC address of your device and enter that in the MAC Address Binding settings. That should work.
Jul 09, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
MAC ADDRESS
- You have to set the Mac Address value after exchange PCB Assy.
(only Bluetooth product)
1. Disassemble the YP-T10 case and Find the MAC Address. (12 digit)
2. Open “memo pad” and write Mac Address on it.
3. Save “BDADDR”
4. Connecting USB, Copy “BDADDR” into Root.
5. To confirm Bluetooth Mac Address
- Power on
- “Setting – My Device Info – View the MAC Address”
6. If an error occurs, the address of the error is saved in
the ErrorMac .txt file as text
7. Mac Address Setting is done.
Dec 12, 2008 | Samsung YP-T10 Digital Media Player
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Compaq Presario 420 ac Logo
12 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
