Question about Dell Latitude E6500 Laptop
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
My Dell Latitude e6500 (running Windows XP) stopped successfully booting up in normal mode (freezing once it gets to my home screen) although it still boots in safe mode. I've managed to retrieve most of my data via safe mode. I get the error code 2000-0146 when I run the BIOS diagnostic test on my Dell Latitude; the first time I ran the diagnostic I got the related error code of 2000-0142 [hard drive self test unsuccessful]. After a lot of searching on tech sites, I've determined others who've had these errors have successfully rehabilitated their hard drives via a series of commands through the windows recovery console--one such command being CHKDSK /r. when I run this command, it says: Volume OS created 08/13/09 05:55a The volume serial number is 5c9f-e82a. CHKDSK is checking the volume... CHKDSK is performing additional checking or recovery... CHKDSK is performing additional checking or recovery... CHKDSK is performing additional checking or recovery... Then it stalls consistently at 55% completed. Any ideas on how to troubleshoot this issue? I've tried other commands to solve the prevailing issue of the malfunctioning boot like bootcfg, fixboot, and fixmbr, all to no avail. The fact that the computer is booting in safe mode makes it feel like a software issue (perhaps corruption of my HDD caused by a virus), but I've run superantispyware and Symantec and Malwarebytes' Anti-Malware in Safe Mode, all turning up no threats.
  • Dell Master
  • 3,799 Answers
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
Posted on May 01, 2013
SOURCE: Crash and Burn dell inspiron 8600 Help
my computer when start I saw the logo of windows, but faster the screen its turned black and dont nothing. I reboot all componet and give me a msg fan are RMP=0, and the hard disk do nothing too.
Posted on Jun 22, 2008
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
  • 3940 Answers
SOURCE: i get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Posted on Dec 11, 2009
  • 1149 Answers
SOURCE: My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
Posted on May 02, 2010
Testimonial: "Great advise. Thank you!!"
MSG-CPC
  • 1325 Answers
SOURCE: My Dell Latitude D630 won't boot up - it does not
go to this link and get the proper support you need. contacting Dell will ultimately address the issue and get it fixed. go to the chat section , have your service code ready (look on back of computer) and have the express service code too.
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central
i am sure this will help
Posted on Nov 01, 2010
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
MY LATITUDE D610 DOES NOT BOOT UP or RATHER IT GOES TO A BLUE SCREEN WITH AN ERROR CODE c0000218 . SINCE IT DOES NOT MOVE FROM THAT BLUE SCREEN I CANNOT DOWNLOAD THE SCAN AND REPAIR TOOLS U RECOMMEND...
Unknown Hard Error, if a corruption of the registry.
Run HDD diags and see if the drive fails, if it does, then the HDD is bad. You can try booting to you XP CD and running CHKDSK in recovery console.
Otherwise, reinstall windows
Sep 24, 2010 | Dell Inspiron 8600 Notebook
XP wont boot and i cant boot from the restore disk. I get error code 1000-0146 when i run the DST Short test
That error code sounds like the Hard Drive is failing or has failed. Can you boot into Safe Mode? Hit F8 as you power up and choose Safe Mode with Command Prompt. If you can, enter chkdsk /r at a command prompt (the black window you'll see). You say you can't boot from the restore disk - why not? Are you booting to the green Dell Windows XP disc that shipped with the computer? Check the boot order in Setup (the BIOS) and make sure it looks to the CD drive first before trying to boot to the hard drive. SpinRite is a good utility for fixing these things, but not free, and involves booting to CD. http://www.grc.com/cs/prepurch.htm
Hope this helps!
Mar 08, 2010 | Dell Latitude D610 Laptop Computer -...
UnmountBLE BOOT VOLUME
Generally and indication of a hard drive problem
Boot to the XP CD, go to recovery console (R at the 1st prompt), run hte command CHKDSK /R
If that fails to resolve, try a repair reinstall of Windows.
If that fails, replace the hard drive
Jan 07, 2010 | Dell Latitude D810 PC Notebook
My laptop wont turn on properly, or really at all. when i turn it on the page comes on which says dell.com, that blue bar at the bottom loads and thats it.. its stays on but nothing happens. what could be...
There could be damage to the Boot Sector files or a problem with the hard disk drive.
First run diagnostics on the hard drive (Fn Key plus the Power Button) see if the hard drive fails diagnostics. If it fails the diagnostic, then replace the hard drive. If it passes, boot to your Windows XP CD, enter recovery console by pressing R at the 1st prompt, then run the command: CHKDSK /R <enter>
Dec 18, 2009 | Dell Latitude D600 Notebook
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
I have a blue screen with the stop code 0x000000ED how do I fix it?
Unmountable Boot Error
You can try to boot to the XP CD, enter recovery console by pressing R, once at the C: Prompt run the command CHKDSK /R and when completed, see if you can boot to Windows. This used to be a big software issue in XP before service pack 1, since then, the usual result is a failing hard drive. But it doesn't hurt to try the CHKDSK fix 1st
Sep 30, 2009 | Dell Inspiron 6000 Notebook
Keeps logging off
If you cannot log into windows in either the normal or safe mode, your repair options are limited.
You can try the following:
  1. Run diagnostics on the hard drive, see if it fails, if the drive fails diags, replace it.
  2. If the drive passes diags, then try booting to recovery console (Boot to XP CD, R at first prompt. Try running the chkdsk /r command.
  3. If no change, try a repair reinstall of windows.
Jul 31, 2009 | Dell Latitude D600 Notebook
My school laptop is messed up
First, see if you can't boot to the F12 menu and run diagnostcs on the hard drive. (At Dell screen press F12, then use arrow keys to select diagnostics) if the hard drive fails diagnostics, yhou are done, and will need to replace the hard drive. If under warranty call Dell for a replacement, if not, then buy a replacment.
If the hard drive passes diagnostics, then boot to the XP CD, press R to enter recovery console when prompted, once at a C:\windows prompt, type the command CHKDSK /R and then let the too run. Once it finishes, try booting to windows again.
If that fails to get you into Windows, then your next step is a repair resintall by booting to the XP CD, and select the installation option to repair previous installation.
Mar 21, 2009 | Dell Latitude ATG D630 Laptop
Dell Latitude E6500 Laptop Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
