Question about Antec TriCool 80mm Blue LED Fan Case Cooling Fan
Computer fan is spinning slowly
I just replaced this fan, with the same type of fan, except this new one has a fan controller. I put the switch on high, to see how it would operate, and it's still spinning at the same speed as the old one. when i start my computer up, it recognizes my side fan as my cpu fan and says my cpu fan is too low, or fail. I just replaced my cpu fan too, so it has to be a false error, anybody know how i could fix this snail of a fan?
Buy another fun and replace the old one
Posted on May 07, 2013
Fan works, put in new light switch, have power though switch and wire leading to sockets but when put in bulb power is not there any more.
If you switched to a different type of bulb with the new light kit, that could be the problem. Some remotes won't work with CFL bulbs.
Sep 19, 2015 | Hunter 52" Ceiling Fan With Light And...
Trying to install a coolant fan switch.
It is almost always mounted in the radiator or next to the thermostat housing,do not mistake Cooling Fan Switch Operation:
00115_cooling_fan_switch.jpgThe cooling fan switch on electric fans monitors coolant temperature signals from the engine control computer. When the engine is cool, the switch opens to keep the fan from spinning. When engine is warm, the switch closes to turn fan on for cooling. How To Instructions:
Inspect - Check for obvious problems.
Test - Give it an in-depth diagnosis.
Replace - Out with the old, in with the new.
the coolant temp sensor for the fan switch.
Jul 06, 2012 | 2005 Honda Element
Not spining
Check for spin control safety switch under cover. Check belt is good & not slipping, replace belt.
Jan 28, 2012 | Hoover Washing Machines
When i switched on my laptop,it showd the warning as cooling fan is not workingproperly.and it got shut down automaticaly within 10 sec. but there is another option present showing start windows...
The computer monitors the speed of a fan inside your laptop.
If the fan stops spinning, or is spinning too slowly to cool your computer, your computer will stop.
Take your computer to a qualified technician, before your computer overheats and REALLY damages itself.
Apr 20, 2011 | Computers & Internet
I have a 1991 Buick Park avenue with 44,000 miles that is not blowing air through the vents. I just put a brand new resistor in and that changed nothing. The fan spins at a low speed when the car is turned...
Switch the relay with one of the other relays to make sure that this relay is good then go to the HVAC control programer which is behind the floor vent (middle). The Blk/gray wire is the one that supports the relay coming out of the HVAC programmer, but there is a chance that this programmer is bad. If that proves to be the case, I may even have one...let me know.
Aug 06, 2010 | 1991 Buick Park Avenue
Won't spin
you are not telling me enough information???most likly belt at rear of machine loose/or off
Nov 11, 2009 | Washing Machines
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
Computer STartup Problem
That is an impressive wait. You must be an OR LP to have tolerated that battery manipulation; hopefully the surgeons aren't up nights over the 3 lost insulated forceps.... It sounds as though the system is dissatisfied with the CPU fan speed or another power/cooling interface component (CPU over 90 centigrade, chipset over 95 centigrade, the power supply fan running, etc.) and thus shutting down immediately to protect itself. Do all those things check out, particularly in the BIOS power/cooling section? How about fan and power connections on your videocard being right and jumpered accommodatingly?
That is, you could connect tach fans on any spare 3-4 pin headers and see if favor comes your way. The system will spin them slowly once it boots and you enable automatic CPU/fan control (and power savings) settings.
May 11, 2008 | Computers & Internet
Fan controller does not work! Power Up (TC3J-4048)
It is bad out of the box. either take it back or email whoever sold it to you and get a new fan. You should not have to pay for a new one.
Dec 30, 2007 | Power Up (TC3J-4048)
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Antec TriCool 80mm Blue LED Fan Case Cooling Fan Logo
146 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
