Question about Pioneer AVH-X2500BT
AVH-X2500BT CD/DVD H/U will play iPod tracks but with no sound.
AVH-X2500BT CD/DVD H/U installed earlier today and I testing it out. I found that when my iPod touch gen 2 is hooked up it will show the tracks and play them but there is no sound. I have checked my wiring and I have also checked the settings on both the H/U and the iPod but found nothing. It is not muted on either the iPod or H/U. What can I do get it to play sound?
SOURCE: PIONEER AVH-P7500 IN DASH DVD PLAYER
DVD IS NOT LOADING
Posted on May 05, 2008
  • 53 Answers
SOURCE: can't get ipod sound on pioneer avic x910bt
try av2
Posted on Jul 30, 2009
  • 6 Answers
SOURCE: CANT PLAY VIDEOS THROUGH IPOD
Select the Source menu, press the OFF key, touch the screen and select AV MENU, and select initial, then touch AV input 1 until it says I-Pod.
Posted on Jan 06, 2010
  • 10 Answers
SOURCE: i have an Avh-p4100 and the Iu200V cable. My DVD
Try resetting the unit using a pen. While powered on, click the reset button and this should resolve your problem. If it doesn't the problem maybe related to parking brake cable not being connected properly.
Posted on Mar 09, 2010
  • 10 Answers
SOURCE: Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Posted on Jul 16, 2010
Dvd region change AVH-X2500BT
Hey,
I own the exact same model as you and I found a video on youtube explaning how to bypass the DVD region. I bought it in the States (region 1) but I live in Brazil (region 4).
See this and if you are not going to intall it yourself show it to yout tech guy: http://www.youtube.com/watch?v=lDGZEZrUdRo
Hope this helps!
Apr 08, 2013 | Car Audio & Video
Not getting any sound from my i-pod Pioneer AVH-P4050DVD
I had the same problem with my Pioneer AVH-P4050DVD
Radio and CD worked fine
DVD would play and I could hear the audio but no video
USB and iPod. It would connect and I could brouse, select and play songs but I would not get any audio even though I could see the track playing, finnishing and moving on to the next one (very frustrating).
Front Aux (Aux 1). I could turn this port on to audio, select it and plus an audio sorce in but no audio would come out.
The solution..
The Pioneer AVH-P4050DVD is odd and different from most other pioneeres in that it has two earth leads that both need to be grounded (2 in addition to the handbreak wire). I had insalled my unit using a toyota - pioneer wireing adaptor I bought from Repco. This adaptor only grounded the wire coming from the corner of the plug (opposite the battery wire). The second earth is located becide the first earth, opposite the ignition wire. If you google pioneer 16 pin wiring diagram it might call this pin BGSENS (pin 13 in the attached photo). With the wireing harness I had this pin was not connected to anything. Once I grounded the second earth (soldered directly to the first earth) everything worked.
Good luck. Hope that helps.
Jan 11, 2013 | Car Audio & Video
I have a AVH-X2500BT I am trying to play a dvd. an error code 02-9e comes up. what is the problem?
The error indicates that the AVH-X2500BT can't read the disc. The DVD could be dirty or scratched or upside down in the tray. Try cleaning the disc or putting in another DVD. The other issue is a mechanical or electrical problem with the unit. Turn off the car's ignition then press the Reset button on the unit. The reset button is recessed and has to be pressed with a pen tip (it's on the far left of the front button array).
The manuals for the unit is available here: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-X2500BT_OwnersManual010213.pdf . See page 4 (page 7 of the PDF) for the location of the Reset button. You will need Adobe Reader or a similar program to read the manual. If the reset doesn't work, you ,may need to have the unit serviced. (Check that your electrical system doesn't have any fuse or ground problems first.)
I hope this helps.
Jan 10, 2013 | Pioneer Audio Players & Recorders
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I Have purchased a AVH P3250,, i cannot play any videos by a usb or even by an ipod, what do i do? and do we need some special cable to play a video through an ipod??? Please Help!!
I've checked out some specs for you, this item cannot play video from an iPod apparently. It will play DivX encoded videos from CD/DVD/USB/SDcard. it will play it will also play dvd's or Video CD. i think the video in these is a wrapper that includes MPEG4 video and some kind of audio. You might be able to play .avi files for example.
Cheers
Moza805
Aug 30, 2011 | Televison & Video
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
Movie plays but screen is black
insert external AGP card in the cpu because internal display card does not suppot to picture or movie the other problems will also automatically solved
Feb 28, 2010 | Pioneer AVH-P4000DVD Monitor
Pionner cd-iu200v plays video from Iphone, no picture on avh4100
Check the initial settings menu (you will probably have to reset the system to get it to reappear) and set the aux 1 to IPOD. This will let the ipod video play via the aux 1 just like it is supposed to. This solution is buried in the manual but is really hard to pull together.
May 11, 2009 | Pioneer AVH-5700DVD DVD AV HEADUNIT...
No video from ipod
Do you have the green cord that attaches to the parking break hooked up?
This stereo is designed so that you cannot watch videos while driving, therefore you need to have the parking break on in order to get video.
when you play a dvd with out the parking break on, you will only get sound.
Mar 18, 2009 | Pioneer AVH-P4000DVD Monitor
Ipod won't play
you're absolutely right. thanks!
Sep 04, 2007 | Alpine CDE-9852 CD Player
Pioneer AVH-X2500BT Logo
76 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
