Question about Garden
Rewind coil spring on poulan 2150 chain saw - Garden
SOURCE: 2375 poulan chain saw brake is shot,how do I fix it?
You Likely by this time have resolved this. Mine messed up one day and I found a spring inside it. This spring wraps around the counter weights and pulls them together at idle speed, allowing the chain to stop, without stopping the motor. As you throttle it up and the RPM increases the spring allows the weights to push outward , engaging the chain. I have used mine without it, but I'm sure that would not be a recommended procedure, as the chain is always engaged, even when idling.
Posted on Oct 26, 2008
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
  • 154 Answers
SOURCE: how to rewind recoil spring
turn opp way then feed string thru to handle with tension
Posted on Aug 02, 2009
SOURCE: Trouble with Poulan 2150 Chain saw automatic chain oiler
Thanks, guys. Right, I do fill it partially now, but it's annoying. Oh well, there is no simple way to restrict the line - I have disassembled the unit and one would only hope the designers would think about a simple device for adjusting oil flow, but there is none. Primitive, since oil will flow at very different rates in cold and warm weather...
Posted on Aug 16, 2009
jeff_drakesr
  • 155 Answers
SOURCE: I have a Poulan 2150 chain saw which needs a new
A new chain pump kit definitely cheaper than a new saw $15.00. Below is a link with the kit for the saw Poulan 2150. Provided to you as reference I don't garrantee site or lowest price. If this has been helpful please rate answer. Good Luck and have a great day. Jeff
Part #530071259
Posted on Apr 04, 2010
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
Lou
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Drum clutch on a chain saw
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installing recoil spring for Poulin P3314
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Rewind pully spring
Lou
Oct 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I have a poulan p3315 14" chainsaw. The the recoil won't work. I took the assembly apart and I can't get the recoil spring back in. I would like to buy a new assembly. Do you know where I can buy one?
Poulan.com Look your saw over carefully and maybe you'll find a model number that matches one of these.
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Lou
Jul 18, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Spring repacement
Hi fwadden
Remove the housing-fan. Remove the screw and detach the pulley- starter and the spring -starter.Put the new spring-starter(it usualy comes with a support).The spring-starter"spires are counterclockwise oriented.Put the puley starter back and the screw.Wrap up the rope clockwise on the pulley-starter until the starter works propperly.Hope this helps you.
best regards savumihai71
Dec 12, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
