Sony str av920
When Powered Up Control Buttons Don't Work Like Tuner,CD,Phone & Others
  • 86 Answers
SOURCE: SONY STR-DG510 Sub woofer does not work
You will need a powered sub because your receiver does not amplify in the sub output.
Posted on Jan 21, 2008
OnlyOneN
  • 86 Answers
SOURCE: Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Posted on Apr 20, 2009
  • 52 Answers
SOURCE: I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Posted on Nov 29, 2009
tech240
  • 169 Answers
SOURCE: Have a Sony STR-DE635 that
Have you checked the rails to ground for shorts. Get hold of a variac as it does make things a lot easier.
Sound like you might have some shorted output devices.
Hope this helps
Thanks for using FixYa
Posted on Aug 18, 2010
  • 102366 Answers
SOURCE: need manual for str av920
You may download a copy of the manual here.
Posted on May 16, 2012
I have a 51 sony cd ..what else do I need?
Yes, Sandra, you need to plug this CD player into a tuner. Almost any tuner will work. Using a red & white audio cord (and any cords with similar plugs), connect the Line Out from the CD player to the Line In on the tuner. Depending on the tuner, you may have Line In inputs for CD player, AUX, and possibly others. Any of them should work.
If you don't have a manual for the player, you can download one from the Sony support web site at :
50 Disc CD Changer
Jun 12, 2014 | Sony CDP-CX53 51-Disc CD Changer
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
I have a Sony Amplifier [model TA-AX380] and other components of CD player [model DCP-C40], AM/FM Tuner [model ST-JX380], FM Stereo/FM-AM Receiver [model STR-AV570X], and Stereo Cassette Deck [model...
http://www.servicemanuals.net/ServiceManual/SONY/TAAX380/148547/detail.aspx
http://www.hifiengine.com/manuals/sony/str-av570x.shtml
Hi above are links for manuals, these may help..
When one wires up anything it is all usually color to color output to input... usually RED & WHITE stereo audio.
Now we would start with our Tuner this the CD player, & Cassette deck, will wire into the Amp's INPUTs , red - red & white - white, these go into the Stereo INPUTs on the AMP... 1, 2 & 3 and be selected via the input selector on the AMP.
Now after all these in's and out's are wired we need to wire our speakers, this too is simple, locate the outputs on the Amp, and wire accordingly, Plus to Plus and Negative to Negative... each speaker has two wires a Plus, + & a Negative -
All will/should be clearly marked and it will be easy to do. You will need patch leads, one set each for each unit, these will be a pair of cables, usually Red & White with RCA jacks on each end, as related these go color to color from the RCA OUTPUTs Sockets, of the signal suppliers, ie: Tuner, FM stereo & Cassette deck... these ALL will wire into the Main Amplifiers INPUTS, usually at rear of unit, and clearly marked, after this is all done, then as related again now connect the Speakers, again the OUTPUT on the Amp will be clearly marked, as output and + & -, + & - (two sets), one for each channel.
Now each INPUT is selected ON the AMP, and it's output will then be directed to the speakers attached to the Amp..... Just wire and test one at a time, and i am sure you will prevail.
Hope this helps.
Jun 20, 2011 | Sony Audio Players & Recorders
Can I connect a passive subwoofer Sony SS-W581T to a SONY receiver STR-DH510 ? Thank you
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Apr 17, 2011 | Sony STR-DH510 5.1 Channels Receiver
How to unlock my stereo. not getting any sound with tuner or cd
If your display is indicating that a source is locked it may be that the source is not powered on or the source input cable is not connected or incorrectly connected.
Jan 06, 2011 | Sony STR-DE897 Receiver
How to reset a sony STR-AV920
Turn it off, you might have to unplug it and leave it unplugged for 10 minutes or so. It should reset itself. Make sure you don't have a wire short somewhere causing an overload to the Amp. You might have to move the turntable further away from the Amp. It is also important to have the T.table Ground wire connected to the back of the Amp/Receiver. Thanks.
Sep 22, 2007 | Audio Players & Recorders
27 people viewed this question
 Grubhead
Grubhead
