Question about Kitchen Ranges
VRT48-6gr-ss Need to purchase supports for grates
Can I use WD40 as a lubricant in my plastic/fiberglass shower tray and stainless steel grate. The grate is extremely difficult to remove & I need something on the external walls of the ss tray.
You can, but the soap will wash the WD40 away. WD stands for Water Displacement and was designed by NASA for keeping electrics free of moisture. Water Pump grease from an automotive shop would be better as it is waterproof.
Feb 01, 2017 | Home
I purchased a 2017 Grateful Dead wall calendar. I received a 2016 wall calendar instead--Order ID: 111-5003018-8961034! How do I receive 2017 GD wall calendar?
You need to contact the seller. You DID NOT buy it from Fixya, so we can't help you except point you in the right direction.
Check out the links, but easier if you check the confirmation email you were sent. In a day or two, you will often get an email asking if you are happy with the purchase.
2017 Grateful Dead wall calendar Google Search
Nov 15, 2016 | Computers & Internet
Where to purchase Dell Inspiron Mini Black 1012 key pad for replacement in Kolkata, West Bengal
you must purchase it from authorized service center because this key pad is available in company. ss contact nearest customer support.
Sep 16, 2011 | Dell Inspiron Mini 1012 Netbook...
How do I clean the stainless steel grate
I don't know what's best to clean the SS grates, but I wait until I fire it up the next time to use a brass brush on my porcelin coated grates. This is mostly because when things are done cooking, I have my hands full carrying and serving things.
As far as the temp not dropping when you turn the heat down, this simply means that this new outdoor oven you bought retains heat well. This is a good thing - and having the temp fall when you open the hood shows this as well.
AnthonyTuition is a small group tuition based in the northern area of Singapore, specialising in H2 Maths and H2 Physics Tuition
Feb 26, 2011 | Sub-Zero 690 Side by Side Refrigerator
I recently purchased a 19"
Your computer graphics, whether onboard or graphics card does not support this resolution.
I think it is a driver problem, click here to download and install the latest drivers.
Fill in the details and select search then download and install.
You may need to purchase a more powerful graphics card.
damnor01
Jan 29, 2011 | HP Compaq dx2000 Microtower PC Desktop
Yamaha gladiator ss valve cleareances
Noise seems to be generating from the rocker arm of the valve adjustment. You have to do valve adjustment only when the engine is in cold condition. ie room temperature.
At this point slip a feeler guage & adjust. first loosen the rocker arm hexagon lock nut & try adjusting the valve pressing post. You may require special tool for this!!
Mar 28, 2010 | 2008 Yamaha Gladiator SS
Need new grate, where can I buy one?
home depot has various different replacement grates, i have purchased them from there numerous times. they are a little pricey because they are generally better quality than the stock grates.
Nov 17, 2009 | Thermos Grill2Go Fire+Ice
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
