Question about Linksys WRT54G-TM Wireless Router
Why is limited internet connection?
In my computer if i direct it, I had a internet connection but if i used the router the command says limited internet connection.
  • 826 Answers
You are facing the limited internet connection only when its secured with the username an password.
Check for it or contact your ISP.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com
Posted on May 01, 2013
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
Posted on Jun 22, 2008
shoran
  • 54 Answers
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Posted on Jan 15, 2009
  • 6 Answers
SOURCE: linksys router will not connect to internet
Routers job are to interpret outside world into your own world.
Linksys Wizard will guide you step by step on how to figure out who is connected to what and where.
At the back of the Linksys Router, there is a small white button if not black, in order for any end-user to reset it back to Factory Default. The purpose of Factory Default is to give you a chance to start from scratch!!!
Press that button for the next 30 seconds while unplugging its power cord. After such time, you will need to plug the power cord back on and your will be ale to Re-run your Wizard to confogure your router.
By the way, Linksys routers comes with a CD in order for you to make your life easy. Have that CD ready and install in your local computer.
I hope this helps. I can't give you play by play instructions on the wizard because I don't have one.
Posted on Jul 24, 2009
LASITHA-VEGA
  • 428 Answers
SOURCE: Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Posted on Jun 13, 2010
I have an HP desktop that runs VIsta that will connect to my wireless router but not the internet.
    , click All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. securityshield.jpg
    If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. At the command prompt, type the following command, and then press ENTER: netsh interface tcp set global autotuninglevel=disabled
    This command disables the Receive Window Auto-Tuning feature.
  4. Close the Command Prompt window.
  5. Restart the computer.
  6. Also try here
How to Fix Local Only or Limited Connectivity in Vista
Jan 22, 2014 | Belkin Components Belkin N450 DB Wireless...
Tip
How to fix limited or no connectivity message with your wireless network...
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
on Nov 20, 2010 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
I have an Emachine t5226 and have several external drives, a modem (speedstream 5100), and a netgear router attached. I was moving the externals, modem and router to a different area. I shut down...
Hello, Unfortunately, ISP techs often try to put blame on their clients equipment as much as possible. If your computer is showing limited connectivity, then this means that it is able to successfully connect to your wireless router, meaning that its probably not your adapter. Limited connectivity usually is a sign that you cannot reach the internet. This could be caused by multiple issues. In order to isolate the problem, try connecting your computer directly into your modem using the cable from the wireless router. If you can connect to the internet, then it is a configuration problem with your router. If not, then it is something with your connection to your ISP, in which case you need to call your ISP back and explain that situation. If you do happen to connect to the internet, then please reply, and we can go from there.
Feb 17, 2011 | Computers & Internet
Can't connect to wireless router
1.Ensure ethernet cord coming from modem is plugged directly into internet port of router.
2.Powercycle equipment (Unplug power from home modem and router wait 15 seconds then plug back in
3.Open Network Connections XP:Start/Run/Type ncpa.cpl
Vista/7 Start/Search bar/Type ncpa.cpl
4. A.Right click on wireless connection the connection you use with router and hit properties,
B.Uncheck Internet Protocol Version 6/ Click on Internet Protocol Version 4 and hit properties,
C.Ensure Obtain an ipaddress automatically is checked
Ensure Obain a DNS server automatically is checked as well
5.Open Command Prompt XP:Start/Run/Type cmd
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt hit run as administrator.
6.Type in Command Prompt: netsh int ip reset reset.log (Hit Enter after each command)
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
7.Restart Computer
8.If still unable to access internet Disable Firewalls/Antivirus
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
My computer is not allowing me to connect to the router wirelessly.
If you are not able to go online using the router then you will need to check the settings of the router.
first you make sure that your computer is able to go online when connect directly to the modem without the router.
If your computer is able to go online through the modem only then your modem is working properly.
Now connect computer to the router and the modem to the router.
you will need to open the setup page of the router to check the wireless settings of the router.
Click Here for step by step instructions
Nov 15, 2009 | Belkin (F5D5231-4) Router
Wireless g router trouble no conectivity
You have to enable DHCP in your wi fi router.
For that connect your wi fi router to youe computer with ethernet cable.
Then access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then Enable DHCP.
Then save settings and exit router.
Also check your wi fi network adapter property Check TCP /IP settings enable ip get automatically.
Then it works fine.
Let me know if you need more assistance.
Thanks.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys WRT54G-TM Wireless Router Logo
78 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
