Question about Canopus ADVC Televison & Video
File write error after 13 sec on canopus dv what should i do, i am unable to capture
File write error
3 Suggested Answers
SOURCE: Canopus converter drops in the middle of capture
Install xp service pack 3.
Posted on May 19, 2008
keithkalish
  • 146 Answers
SOURCE: why when i captured from camera the captured file
If you are talking about a hand held video camera it is your hand shaking, it becomes more apparent if yo zoom in on something very far away. If you camera is equipped with a video stabilizer function, make sure it is enabled. If you are talking about a web cam, make sure it is secure and there is no extreme vibration going on in the room. Even loud audio especially with a cranked up sub woofer could prvid eenough vibration to affect your video
Posted on Oct 01, 2009
Can I capture a video file from an ordinary PANASONIC camcorder SDR-HR5 with just a USB adaptor and edit it using my CANOPUS RAPTOR EDIT i LINK data port. or can i capture videos from my PC to my...
Not to my knowledge, however there are lots of "video grabbers" on the market, they are an external piece of hardware that will take the composite outputs from your cam corder and download into your PC through the USB port. Amazon has a large selection and they are fairly low priced..Hope this gives you some insight on the problem...Dave
Mar 30, 2011 | Canopus DVStorm2 Pro (Bundle) Graphic Card
Thanks for this thread, I am so frustrated. I ;have a windows pc with XP sp2. I use Windows Movie Maker, mostly. I have a pinnacle av/dv card, which has a firewire input, as well as the rca jacks. Feeding...
i love a well informed person with computers. so many people post here and don' t give any other information; and for that i thank and congratulate you. now for your resolution. i have read up on this particular unit and with this one i have found several hundred issues with the quality. especially when viewing on larger LCD screens.
knowing this, i suggest the upgraded model. Canopus ADVC 300 Analog / Digital Video Converter......http://www.firewire-1394.com/canopus-advc-300.htm
now with that said you mentioned you have a pinnacle av/dv card. my question involves the issue with your firewire. on most cards of this nature they want to be "alone". meaning that the card wants to be in a pci slot to itself with no neighbors. i suggest putting it in the very first slot available to avoid this and then putting your other cards in the remaining slots. this card you are using is also a little outdated. here is a better card.... http://cgi.ebay.com/Compro-Videomate-C500-PCI-DV-Analog-Capture-Card-2-/170586107840?pt=AU_Components&hash=item27b7b96fc0#ht_1080wt_905
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Canopus ADVC-110 A/D Converter...
Let's edit 2 doesn't work with windows 7 I can't install it, can someone help me?
Installing LE2 in Windows 7:
install a newer version of QuickTime than the 6.x included with LE2
run Setup.exe in the "Let's EDIT 2" folder of the LE2 disc
(do not use SetupMgr.exe in the parent folder!)
enter your serial number
continue the installation until the unhandled exception occurs
Error number: 0x80000FFFF
Description: Catastrophic failure
do NOT close the error window yet!
(otherwise the installed files will be deleted)
use the windows explorer and go to C:\Program Files\Canopus\
(the chosen installation location)
rename the "Let's EDIT" folder, for example "Let's EDIT.save"
go to C:\Program Files\Common Files\
rename "Canopus Shared" to "Canopus Shared.save"
make a copy of the desktop shortcut
(copy - paste shortcut)
make a copy of the "Canopus Let's EDIT 2" start menu folder
now click OK in the exception error window and wait a few seconds
restore the "Let's EDIT" folder name
restore the "Canopus Shared" folder name
start Let's EDIT and adjust the settings
especially video standard (NTSC/PAL) and format (DV/DVCAM)
close Let's EDIT
add the following entries to the registry in order to allow installing 3DRT
(adjust DestDir if installed into a different path)
these entries will also allow installing the 3DRT update
(if you have the updated 3DRT 2.01 version that has the improved 3D PIP)
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Canopus\Let's EDIT\Installation]
"DestDir"="C:\\Program Files\\Canopus\\Let's EDIT"
"SetupVersion"="2.03"
run install.exe in the "3D RT" folder of the LE2 disc
(or install 3DRT 2.01 instead, if you have it)
Apr 06, 2010 | Canopus Let's EDIT 2 (77610158100)
Unable to get dv input / output via ieee 1394 port
try an older version of pinnacle studio or another pc if still no capture, firewire camera board failed.
Oct 24, 2009 | Panasonic AG-DVX102AE DV Digital Camcorder
Cant capture video
Not having camcorder control is normal, as the ADVC110 doesn't translate DV (AV/C) control to anything else. It just accepts and replies to deck control commands so the capture application doesn't get stuck waiting for a response.
First off, make sure you only have the ADVC110, your VCR, and your computer connected. No other Firewire devices.
Be sure your have the output from your VCR connected to the ADVC's input. Connect your VCR's output to your TV. You should see in iMovie the same image you see on your TV, slightly delayed.
Jul 04, 2008 | Canopus ADVC-110 A/D Converter...
Problem in video capturing through firewire
Hi Sreeki,
You may have solved this problem already but I had the same problem some time ago, so the advice will be a little vague.
From memory the issue is something to do with corruption of a directx file so you could just try re-loading directx.
But the way I found a solution was to try and capture video using windows movie maker and you will find the video capture also fails using this software. However, windows returns an error message (which I cannot remember), and I did a search on Google or something for this error message and eventually found the solution.
It was related to directx and there was a small file that had to be run to repair it.
Hope this helps and I will continue searching for the problem I am now having with my camera not accepting a tape and returning the error message relating moisture......
Mar 29, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
Editing
dear jose thomas
Just trying using a canopus 4.0 for your ACEDvio ..it compatible with your canopus DVstorm
and your problem can solve with a correct codect or using edius 4.0 to capture your video
ok, post in me back
thanks
cropp
Mar 17, 2008 | Computers & Internet
Loading a clip
It really depends on what format the video is in. AVI files are just containers - they can contain various different video formats.
EDIUS v4 supports more AVI formats, so if it plays in Windows Media Player, then it's more likely to work in EDIUS v4.
EDIUS v3 supported only Uncompressed, DV, Canopus HQ, and Canopus Lossless AVI clips.
Jan 25, 2008 | Canopus ACEDVio/EDIUS Pro 3 Bundle...
Televison & Video Logo
243 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
