Question about Exercise & Fitness
Cord frayed - Exercise & Fitness
How to fraying fix charger cord
While you can try to fix the fraying charger cord with heatshrink tubing available at a local electronics store, the best option is to replace the charging cable, because once the cord frays, the integrity and quality of charge is negatively effected and could damage your iPod with prolonged use.
Jul 19, 2014 | Apple iPod Audio Players & Recorders
Tip
Safety For Electric Mowers
<span> <ul> <li>Use only recommended, grounded extension cords.</li> <li>Mow away from the cord.</li> <li>Never abuse the cord or use a frayed cord.</li> <li>Always turn off the mower when you leave it and unplug the cord directly from the outlet; never unplug by yanking the cord from the wall.</li> <li>Never use an electric mower when wet or raining</li></ul></span>
on Apr 02, 2011 | Garden
Our Tiger shark has to be hauled out of pool by power cord. The cord has frayed and the shark won't run. Where can I have it repaired? I live in Gainesville Fl.
the power cord can be changed by a service pro. there are special tools required to perform this task. not to judge, but exercise more care when removing the unit. According to the hayward website, there are two dealers in gainsville at your disposal. they are both 'pinch a penny' stores. this link should take you to the address
Encuentra un profesional de piscinas
May 08, 2014 | Aqua Vac Tiger Shark
Electric dryer cord is frayed
You need another pigtail that one is no good. Their is no fix. Replacement cord must be installed.
Feb 08, 2014 | Roper Dryers
Kenmore vacume
after turning the switch on, jiggle the electric cord at the vac end, not the plug end.
Anything happen?
Most of the time the cord gets frayed from repeated bending. To fix, you just unplug the vac, cut the cord behind the frayed place, and reconnect it to the switch after removing the housing.
Jan 08, 2014 | Washing Machines
Was useing kango breaking concrete and it stopped working
Check:
  • frayed wires where it enters Kango
  • is power at switch
  • Power thru the switch
  • Frayed wires at cord plug
  • And finally - Brushes
These are the EASY checks, if none of the above, take it to your local service center.
Good Luck
Nov 09, 2013 | Hammering
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
Jul 13, 2011 | Oreck Cordless Speed JP8100CA Iron
Black electrical cord is frayed.
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
May 04, 2010 | Gold Medal 5020 Waffle Maker
Frayed elastic cord
call 800-872-6765, or www.1800trampoline.com
click on the trampoline and at the bottom of the description it says click here to order parts.
Apr 14, 2009 | Kid Riffic Toys Kidriffic Jump Smart
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Exercise & Fitness Logo
593 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
