Question about Caterpillar D5g Xl Track Type Tractor By Norscot 55131
Cat diagram leaking oil out of the hydrostatic pump
What would cause hydrostatic to stop working
Usually this is due to a low oil/fluid level in the transaxle. Over time, these units develop leaks. Just be sure to install the proper oil/fluid recommended for you unit.
Nov 15, 2015 | Garden
Signs bad water pump
Water in the oil which would look like chocolate milk. Oil in the cooling system which would look like tar or black dots floating in the coolent. Or a visible leak of coolent on the floor or ground. After checking the hoses and related gaskets for leaks look at the weep hole on the water pump. If there is coolant around the hole then the pump seal is bad.
Aug 17, 2014 | Arctic Cat 2005 500 4x4 Automatic LE
Oil leaking from where stainless steel meets aluminum body, what is the part packet I need to get. Ordered
it's an oil seal total of 3 possibly a 20x30x7,carfully pry the seal to see it's number you can get these seals from a store that sells bearings and shaft like miller bearing or go to pressure washer website and input the cat model #,hope this helped
Mar 16, 2013 | Cat Pump 3CP1231 - Stainless Steel Plunger...
How can i fix a leaking hydrostat on 2001 toro timecutter 18/52
you need to clean off the oil and see where the leak is a hose or a seal
Sep 27, 2012 | Garden
863 bobcat getting oil in fuel
Internal leak in lift pump. Leaks fuel into cam to oil pan.
Jun 21, 2012 | Bruder Cat Skid Steer Loader
Hi, My Dewalt 3100 pressure washer pump wash leaking water from a check valve or overflow plug Do you know whats wrong?
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Sep 08, 2011 | Dewalt DPH3100 Gas Pressure Washer
Valve train noise, engine oil loss, no leak
It is burning the oil,and it is not noticable ,and the oil pump is either weak,or the cam/crank,rod bearings are worn,and the pressure does not make it up yo the valve train.
Jan 16, 2010 | 2003 Nissan Xterra
Oil leak
the dealer parts dept usually has the best exploded diagrams
Sep 30, 2009 | 2003 BMW 325
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
Hydrostatic drive squeels and stops pulling when hot
I had a similar thing go wrong. Even though the hydrostatic drives are designed so that the fluid doesn't need to be changed, If it is a hydrostatic transaxle check to see if it is leaking,if it is then there really is no repair to transaxle. If it isn't leaking then It sounds like the oil in transaxle is worn.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 Allen wrench fitting on top. You will need to purchase suction bulb and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion
Aug 13, 2009 | Mtd Garden
Caterpillar D5g Xl Track Type Tractor By Norscot 55131 Logo
Top Caterpillar Toys Experts
fordexpert
Ted Maxwell
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
