Question about Dell P2210 Monitor
Dell p2210 monitor disassemble - Dell P2210 Monitor
2 Suggested Answers
SOURCE: how to disassemble monitor Dell 1800fp ?
Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
Posted on Jul 15, 2009
How do I get P2210 monitor to work with USB with Dell Inspiron 15R that doesn't have a VGA port
The Inspiron 15R should have an HDMI port. You should be able to connect the HDMI to the DVI-D port on the P2210 with a cable like this: http://www.monoprice.com/Product?c_id=102&cp_id=10231&cs_id=1023104&p_id=2661&seq=1&format=2 . Alternatively, you can get an HDMI to Display Port adapter. Connect either cable with the notebook and monitor both off. Then turn on the monitor before turning on the computer. Pressing F1 should send the signal to the monitor. However, if you right click on the desktop (anywhere there isn't a program or icon), you should see some links for DIsplay options. You can use those to select the monitor resolution and whether to use both screens (extended or mirrored) or one at a time.
The most expensive option would be a USB to video adapter, see http://www.startech.com/AV/USB-Video-Adapters/ , or docking station. These come with VGA or other video output ports depending on the model. The USB ports on the monitor are just an integrated hub to plug in an external devices. It doesn't communicate to the display.
I hope this helps.
(The DVI to HDMI cable doesn't supply audio but that doesn't matter in this case. However, you may need to go into the Manage Audio devices control panel and disable sound on the HDMI port. Open the Control Panel (Windows + X in Windows 8 or from the Start Menu with Windows 7). Go to Hardware and Sound and then look for Manage Audio Devices under Sound. In the playback tab, adjust the default audio device by right-clicking on the appropriate device. Then click Apply.)
Jan 25, 2015 | Dell P2210 22 inch Monitor
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
Aug 27, 2014 | Dell P2210 Monitor
What is the 2 answer for unlocking the p2210t moniter menu
All answers are in the User Manual :
http://www.manualmonitor.com/dell-p2210
How to diassemble1707 dell monitor
i would not recommend disassembling a monitor unless you are a Dell Certified expert.
Jul 26, 2014 | Dell Computers & Internet
Vertical pink line across dell p2210 monitor
Mine has a green line. I changed the background to green. It's broken, you can buy an new one or cover it up.
Sep 07, 2013 | ViewSonic OptiQuest Monitor
My Dell Monitor P2210 USB Ports Not working
Do you need a USB cable from one of the USB ports on your computer to a USB port on the monitor?
Feb 04, 2012 | Dell P2210 Monitor
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Dell P2210 menu is locked, how do I unlock it?
You have to hold down the top and bottom buttons at the same time for around 10-15 seconds and it will eventually display an unlock icon and you are back in business..
Sep 07, 2010 | Dell P2210 Monitor
Dell P2210 Monitor Logo
930 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
