Question about ViewSonic VX900 19" LCD Monitor
Viewsonic VX900 turns on for second then shuts off
The 19" LCD monitor turns on for a second and then goes off, but the green light stays on, by the power button, and can turn off and turn on again and it stays on for second and shuts off. Ive done some research saying it maybe power supply or Backlight was wondering if you knew how to diagnose the power supply board to be faulty or any other fixes that may help Thanks
  • 11 more comments
  • Anonymous Nov 17, 2007
    My 2 yr old lcd vx900 monitor suddenly went blank except when I cycle power. The image then appears just fine for one second and then goes blank again and stays there. i have done some research and i think i can be the inverter (power). please let me know if im right.
  • Scottocs Dec 23, 2007
    My Viewsonic VX900 has been working great for the past few years but now is doing the exact same thing to me as well. It turns on/powers on, shows the image for s slit second, and then goes blank, but still being powered on.
    Before this happened I did switch the monitor from my PC to laptop so I think it may have something to do with the resolution change that messed it up.
    I haven't gotten to call Viewsonic yet, but hope there is some way to reset it back to normal for us having this problem!
  • cdcragg Dec 28, 2007
    I have exactly the same problem.
  • Vincent Harkin Dec 31, 2007
    turns of for a secon
  • Anonymous Jan 15, 2008
    My VX900 now seems to be doing the same thing as described here as well. Does anyone have any ideas/tips on getting it repaired/fixed???
  • Skattnaway Jan 15, 2008
    My LCD has been sitting and collecting dust, hoping for some working solution as well.
  • ayooo Feb 13, 2008
    View sonic VX900 i turn it on after rebooting my computer and the Monitor blinks one time but does not stay on
  • digidigo Mar 31, 2008
    same problem with a brand new Q241WB from Buy.com
  • Anonymous Apr 03, 2008
    922dx must be repeatedlly turned on and off until it catches, once on it stays on
  • LiamSherborn Sep 17, 2008
    My issue is exactly the same. I have another monitor that works fine and when I switch the cables, the other continues to work so it is not the graphics card. Any thoughts. I feel like I have lost an eye.
    Liam
  • rxmeng Mar 30, 2009
    I have View Sonix VX1940W. When I turn on, the monitor would come on for about 5 seconds than I heard the buzzling sound after that it shut off..However, the power light indicator still stay on..Any advise greatly appreciated..
  • Anonymous Mar 21, 2014
    intermittently flashes on, no obviously blown caps. Replaced low voltage caps on the power supply board
I had to replace a fuse(F1) on the inverterboard of my VX900 to get it back to life as fuzzytek sugested.
It was replaced by a normal "flat" fuse (for cars). Had no clue about the value, so I tried with 0,5A first. It blew right away. Next value I had was 2A, and it worked! (It might be too small, and it might be too big, but I think it is better to usa a "large" fuse rather than no fuse at all. :)
Some pictures from my installation:
Posted on Apr 11, 2008
    Problem Solver:
  • 7 Answers
As far as the vx900 2 second screen there are 2 fuses on the inverter board that need to be checked. as far as the vx 910 that gundam84andy posted there are capacitors that need to be replaced.
Posted on Feb 10, 2008
  • MrFloppy Feb 11, 2011
    How do you open up the case???
    New Friend:
  • 3 Answers
I just repaired my Viewsonic 2235 which was turning on for 30 secs or so then turning off although the power light stayed on. Turns out there were three capacitors that needed replacing - all were 200uf25v - very easy to replace (replaced with 220uf65v) and the monitor is now working fine. Thanks to all for the tips found here!
Posted on Nov 19, 2009
    Problem Solver:
  • 11 Answers
Check the 100uf capacitor near the black plug leading to the audio board. It won't look bad but replace it anyway. Fixed 10/12 bad ones we had.
Posted on Mar 26, 2008
I've been reading posts from all over the internet, and have actually taken a Viewsonic VG700B apart, and looked at its internals. Definitely has bad capacitors, they're bulging on top. This unit I picked up today from a computer recycling center in KCMO. I turned it on, it showed a beautiful picture, then went blank. Definitely needs capacitors changed out. I also have a KDS LCD flat panel that has issues, funky screen in boot up, and windows. So, possibly an expensive fix. However, I have a Generic 15" flat panel that only needed a power supply change to repair it. I used a Y connector like you'd use in a computer to give more connections to the power supply. It can now run either by the internal PSU in my computer, or on a power supply for an IDE to USB hard drive. It's been running on this for 6 months now.
So, check your board inside your monitor, if it's swollen, it's bad, and needs to be replaced. Easiest way to test power supply would be to borrow a power supply from someone with a known good power supply for a comparable monitor. Or you could build one using a mollux connector, a couple of wire splices, and a working Y connector. Viewsonic VX900 turns on for second then shuts off - moz-screenshot-1.jpg moz-screenshot.jpg
Guys, it is not the power supply. I checked the power supply, it is OK. It is the inverter. I checked the inverter on the ebay and it is costing 79.99 before shipping. Now I am trying to get the generic which is used in case lighting. It cost about $10.00 including shippment but I have to modify it. I don't know yet how I am going to make use of dimmer and on off feature. As soon as I am done I will post it.
Posted on Jan 24, 2008
This is the solution for my Viewsonic VA-912B, i resoldered the pink wire to the right of the picture shown. I had the same exact symptoms everyone else seems to have. Its in the high voltage section of the inverter. I'm guessing it became a cold solder joint over time.Viewsonic VX900 turns on for second then shuts off - effc653.jpg
Posted on May 08, 2009
Posted on Apr 24, 2009
How could this be the power supply? I currently have a problem with the monitor, If you weren't getting the correct wattage to begin with, wouldn't it not turn on in the first place? I'm a networking guy and OS, not hardware. The light does indeed stay on. It stays on for a second at most, going black. Somewhere else said a dead pixel, but I would think you'd see it for the second it turns on. ( Giving enough time you turn it on enough to see the screen little by little). Could someone with SOME credential lead us int he right direction? If it helps, drivers don't seem to diagnose.
Posted on Nov 24, 2007
Try to replace the electrolytic capacitors before the inverters.
Posted on Oct 03, 2009
I have the same problem but my model is VX910 or 924, don't remember which one it is. The weird thing is that when I try to even press the power button it didn't do anything. However; I did try to unplug the power cord and plugged it back in and it'll turn on by itself. So It could be the power supply.
Note: This problem doesn't occur all the time, like during the last weekend the monitor was running just fine all day but then yesterday it just died on me again. I really don't want to spend money to get another one, so I'll see what I can do to repair this problem.
Posted on Jan 15, 2008
    Problem Solver:
  • 11 Answers
It is the power supply try and get one from ebay or somewhere like that its a lot cheaper than most places
Posted on Aug 08, 2007
SOURCE:
I have a desktop monitor. Once i turn on the monitor it stays lit for 2 seconds then goes black. The light stay on. I then touch the power button on the monitor to turn it off. I then repress the power...
The inverter circuits or the power supply for the inverter circuits have failed due to bad caps, cold solder joints, shorted transistors.
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
If you do want to spend money on tools and troubleshoot it down to component level, you can replace the board, here:
http://www.lcdrepair.us/Invpowersupply.html
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 21, 2011 | Dell E193FP 19" LCD Monitor
As soon as I turn on the Hyundai X93W monitor, it stays on for a couple of seconds, then the screen goes black, but the green light next to the power button is still on. I'm not sure when this problem...
josealvajr, Check YOUTUBE again!! Use search terms: "lcd monitor repair" and "lcd monitor disassembly" and you will find some video clips that may not be for your unit, but will help you. All ccfl back-lit lcd monitors use same basic electronic design to display text and images on the lcd panel!!! Hyundai probably won't sell you a inverter/smps board. Look for swollen capacitors on the power supply board. Lots of pic's on web for you to look at. 12fixlouie
Oct 19, 2010 | Hyundai Electronics Hyundai LCD 19"...
I am powering up and the flat screan turns on and
More likely to be bad caps (bulging top/seal) in the power supply, which when they failed, they may have taken out the inverter fuse on the transistors in the inverter circuits also. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 14, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor only stays on a few seconds
You have a burned out Backlight Fluorescent Bulb.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Benq fp91g+ monitor doesnt stay on
Hey...Superb****,
It's seems your monitor it *******...Hehehe... Due to busted backlight inverter.
Need to replaced a new one or repaired it.
Jul 09, 2008 | BenQ FP91G+ 19" LCD Monitor
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
On off problem
Sounds like it's faulty. is it under warranty?
Feb 20, 2008 | ViewSonic VX924 19" LCD Monitor
LG Flatron L1951S-SN 19 in. Flat Panel picture problem
When the picture disappears again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 15, 2007 | LG Flatron L1951S-SN 19" LCD Flat Panel...
ViewSonic VX900 19" LCD Monitor Logo
9,630 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
