Question about Lenovo thinkvision lt2252p 22in lcd mon wide led 16x10 2572mb6
Thinkvision monitor power saving mode - Lenovo thinkvision lt2252p 22in lcd mon wide led 16x10 2572mb6
2 Suggested Answers
drbelitz
  • 79 Answers
SOURCE: My Lenovo Thinkvision monitor stuck in sleep mode.
You may need to blow the dust out of the back of the monitor or get a new rebuilt monitor. They run about $30 at shops that rebuild them. Usually good will stores have computer stores attached to some of them. The computer store in Omaha is Called good bytes.
Posted on Feb 12, 2015
How do i get my thinkvison to get out of power saving mode
I do not know how many Thinkvision models are out there, but here is a site that offers manuals you can read online or download.
This is just a page from the manual I found. Here is a link to the manual I found. http://www.manualslib.com/manual/91948/Lenovo-Thinkvision-E54.html#manual
THIS MONITOR WILL APPEAR TO BE NON-FUNCTIONAL IF
THERE IS NO VIDEO INPUT SIGNAL. IN ORDER FOR THIS
MONITOR TO OPERATE PROPERLY, THERE MUST BE A VIDEO
INPUT SIGNAL.
This feature is designed to conserve electrical energy by reducing power
consumption when there is no video input signal present.when there is no
video input signal present.When there is no video input signal, this monitor,
following a time-out period,will automatically switch to an OFF mode. And the
LED will turn orange. This reduces the monitor's internal power supply
consumption. After the video input signal is restored, full power is restored
and the display is automatically redrawn. The appearance is similar to a
"Screen Saver" feature except the display is completely off. The display is
restored by pressing a key on the keyboard, or clicking the mouse. Lenovo ThinkVision E54 User Manual
Feb 28, 2015 | Lenovo ThinkVision Computers & Internet
Feb 12, 2015 | Lenovo ThinkVision L192 19" LCD Monitor
Monitor goes into power saving mode while working with xp operating system
Probably not a problem with the monitor but rather the power settings for windows. right click on the desktop and go down to properties select the screensaver tab and click the power settings button. Under here you can change the settings for when the monitor shuts down. Personally I would select never.
Aug 17, 2011 | IBM ThinkVision L190 19" LCD Monitor
Thinkvision monitor is in power save mode. It is not connecting to Thinkpad laptop
There are 2 possible reasons for this:
- Your Laptop resolution is not supported from the monitor. Solution: reduce the resolution to something smaller (e.g. 800x600) and then gradually increase it untill you have the maximum accepted resolution from the monitor.
- You have not switched the Laptop display to point to the external monitor. Solution: do that b pressing the corresponding shortcuts in your Thinkpad keyboard. (usually a bottom left key together with a top key).
Jul 28, 2011 | IBM ThinkVision L200p 20.1" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
Monitor in power saving mode, can't turn on computer., what is power saving mode
You may have power supply problem in the monitor (90% of the LCD monitor failures are due to bad caps in the power supply).
Try it on another PC, also check all the pins on the VGA cable. If it still does not work and you want to DIY repair, the plase read below;
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision monitor is stuck in power saving mode. how do i get it out of it?
I would try it on other PC first to narrow down the problem.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Apr 10, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
UNABLE TO ADJUST THE SCREEN ALWAYS SHOWING MENU LOCKED
When you press power button press continues F8 key then you see safe mode and other menu enter in "ENABLE VGA MODE'
then go to dispaly property and settings then change screen resolution to 1024.768
then apply and ok.
Aug 18, 2009 | Lenovo ThinkVision L151p (Black) 15 inch...
IBM THINKPAD
Hi...there,
It's seems your Thinkpad need a new inverter, due to a backlight inverter burnt out. Get a new one or repaired it. Good lucks!
Sep 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
Lenovo thinkvision lt2252p 22in lcd mon wide led 16x10 2572mb6 Logo
104 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
